Inleiding
The motherboard functions as the central hub for all of the components in your device. If one or more components cease to function, the motherboard may be faulty. Follow the directions in this guide to replace the motherboard in your device.
Wat je nodig hebt
Remove the five 2mm Phillips #000 screws that are under the screen of the camera.
Remove the three, blue 5 mm Phillips screws from the back plate.
Remove seven 2 mm Phillips #000 screws.
Remove the 5 mm Phillips #000 silver, anchor screws from the corners of the motherboard marked in the picture.
Één andere persoon heeft deze handleiding voltooid.
