Ga door naar hoofdinhoud
Canon PowerShot G3 Speaker Replacement
Wat je nodig hebt
  1. Canon PowerShot G3 Speaker Replacement, Speaker: stap 1, afbeelding 1 van 1
    • Start to remove the screws around the camera: from the front, back, sides, and bottom.
  2. Canon PowerShot G3 Speaker Replacement: stap 2, afbeelding 1 van 1
    • Once the screws are removed, remove the back panel. The panel should be able to be removed by hand.
  3. Canon PowerShot G3 Speaker Replacement: stap 3, afbeelding 1 van 1
    • Next remove the front and right side panels (the left is attached to the front panel).
  4. Canon PowerShot G3 Speaker Replacement: stap 4, afbeelding 1 van 1
    • Finally, remove the top panel as shown.
  5. Canon PowerShot G3 Speaker Replacement: stap 5, afbeelding 1 van 2 Canon PowerShot G3 Speaker Replacement: stap 5, afbeelding 2 van 2
    • The front of the camera should now resemble the picture shown. (Image 1)
    • Remove the capacitor/speaker housing using your finger nail or other thin object to lift it up around the edges. (Image 2)
  6. Canon PowerShot G3 Speaker Replacement: stap 6, afbeelding 1 van 1
    • To remove the circuit ribbon (brown strip) pull it out of the plastic piece it is connected to.
  7. Canon PowerShot G3 Speaker Replacement: stap 7, afbeelding 1 van 1
    • You should now be able to see how the capacitor/speaker housing slides out of the frame.
  8. Canon PowerShot G3 Speaker Replacement: stap 8, afbeelding 1 van 2 Canon PowerShot G3 Speaker Replacement: stap 8, afbeelding 2 van 2
    • Disconnect the speaker wires from the camera, then use a small flat head screw driver to lift the speaker out of its housing.
    • Order a new speaker from the manufacturer or take it to a local electronics store to see if they have one.
Conclusie
Ryan Riales
201 Reputatie
2 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 4
Altijd: 248
