Deze versie kan foutieve bewerkingen bevatten. Schakel over naar de recentste gecontroleerde momentopname.
Wat je nodig hebt
Deze stap is niet vertaald. Help het te vertalen
On the bottom of the camera, push and slide open the battery compartment.
Remove the battery.
Open the screen.
Remove the Phillips #0 screws on the end of the screen.
Remove both Phillips #0 screws on the opposite side of the screen, located near the hinge.
Remove the back panel of the screen, using a spudger or opening tool if necessary.
Remove both Phillips #0 screws at the top of the screen.
Turn the screen perpendicular to body of the camera.
Remove the Phillips #0 screw at the base of the hinge.
Push the screen down and away from the camera.
Remove the single Phillips #0 screw at the base of the rotating arm. This will allow you to remove the screen cover.
Remove the black bar attached to the data ribbon cable. You will use this with the replacement.
Slide the black bar from underneath the white socket.
2 opmerkingen
I'm guessing that the screen is OK and the wiring/connections is the problem.
