Deze handleiding heeft recentere wijzigingen. Schakel over naar de nieuwste niet-geverifieerde versie.
Inleiding
In this guide we will be replacing the screen of a Canon PowerShot G3.
Wat je nodig hebt
On the bottom of the camera, push and slide open the battery compartment.
Remove the battery.
Replace back panel. Make sure the metal part of the panel goes under the metal part of the rotating arm or the screw won't go in.
Put the four screws back in from step 2 and 3 respectively.
Step 2 screws go in the outside of the panel. Step 3 screws go in on the underside of the panel.
2 opmerkingen
I'm guessing that the screen is OK and the wiring/connections is the problem.
