Ga door naar hoofdinhoud
Canon PowerShot G11 Top Cover Replacement
Wat je nodig hebt
  1. Canon PowerShot G11 Top Cover Replacement, Front Cover: stap 1, afbeelding 1 van 2 Canon PowerShot G11 Top Cover Replacement, Front Cover: stap 1, afbeelding 2 van 2
    • Push the button on the bottom right of the camera and then remove the plastic surrounding the lens.
  2. Canon PowerShot G11 Top Cover Replacement: stap 2, afbeelding 1 van 1
    • Use the spudger to pop off front case.
  3. Canon PowerShot G11 Top Cover Replacement: stap 3, afbeelding 1 van 1
    • Pull the loosened cover off and you are finished.
  4. Canon PowerShot G11 Top Cover Replacement, Top Cover: stap 4, afbeelding 1 van 1
    • Once both the front and rear covers are removed, disconnect this ribbon cable by flipping it up and disconnecting it.
  5. Canon PowerShot G11 Top Cover Replacement: stap 5, afbeelding 1 van 1
    • Remove these three screws from the rear side of the camera.
  6. Canon PowerShot G11 Top Cover Replacement: stap 6, afbeelding 1 van 1
    • Remove this screw from the front of the camera.
  7. Canon PowerShot G11 Top Cover Replacement: stap 7, afbeelding 1 van 1
    • Disconnect this cable from the motherboard by sliding it in the direction of the cable (toward the top of the camera).
  8. Canon PowerShot G11 Top Cover Replacement: stap 8, afbeelding 1 van 1
    • Remove the top cover and you are finished.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Dustin Brinegar
688 Reputatie
4 handleidingen geschreven
USF Tampa, Team 5-6, Brown Winter 2015 Lid van USF Tampa, Team 5-6, Brown Winter 2015
USFT-BROWN-W15S5G6
3 Leden
6 handleidingen geschreven
Één opmerking
In step 5, it is only necessary to take out the 2 SST screws at ~ 10 and 3 o’clock. The grey screw at 7 stays with the body.
In step 7, you need to SLIDE the connector toward the top of the camera toward the dial. The tweezers in the photo are moving LEFT, not toward the viewer as I interpreted it. If you lift it up as if to disconnect a socket (like in step 4) away from the mother board with tweezers, you’ll easily destroy the delicate connector (as I found out).
Dimwit - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 16
Altijd: 1,626
