Ga door naar hoofdinhoud
Canon PowerShot G11 Rear Dial Replacement
Wat je nodig hebt
  1. Canon PowerShot G11 Rear Dial Replacement, Rear Cover: stap 1, afbeelding 1 van 1
    • Remove the three screws on the bottom of the camera using the 00 sized phillips head screw driver.
  2. Canon PowerShot G11 Rear Dial Replacement: stap 2, afbeelding 1 van 1
    • Remove the four screws on the left side of the camera.
  3. Canon PowerShot G11 Rear Dial Replacement: stap 3, afbeelding 1 van 1
    • Remove the screw on the right side of the camera.
  4. Canon PowerShot G11 Rear Dial Replacement: stap 4, afbeelding 1 van 1
    • Open up the HDMI port on the right side of the camera. Then remove the screw in the HDMI port.
  5. Canon PowerShot G11 Rear Dial Replacement: stap 5, afbeelding 1 van 1
    • Remove the screw to the right of the view finder on the rear of the camera.
  6. Canon PowerShot G11 Rear Dial Replacement: stap 6, afbeelding 1 van 1
    • Use the spudger to crack open the case.
  7. Canon PowerShot G11 Rear Dial Replacement: stap 7, afbeelding 1 van 1
    Gereedschap gebruikt in deze stap:
    Koop
    • The rear case is still attached to the camera with a ribbon cable. The socket has a flip up lid that must be flipped up before the cable can be removed. Use the tweezers to flip the cable attachment up.
  8. Canon PowerShot G11 Rear Dial Replacement: stap 8, afbeelding 1 van 1
    • The rear cover is now unattached from the camera.
  9. Canon PowerShot G11 Rear Dial Replacement, Rear Dial: stap 9, afbeelding 1 van 1
    • Remove the plastic covering of the left side of the rear case interior.
  10. Canon PowerShot G11 Rear Dial Replacement: stap 10, afbeelding 1 van 1
    • Remove the four screws that are now accessible with the removal of the plastic covering them.
  11. Canon PowerShot G11 Rear Dial Replacement: stap 11, afbeelding 1 van 2 Canon PowerShot G11 Rear Dial Replacement: stap 11, afbeelding 2 van 2
    • After the screws are removed, pull the metal bracket out of the camera.
  12. Canon PowerShot G11 Rear Dial Replacement: stap 12, afbeelding 1 van 1
    • Push the dial out from the other side of the cover.
  13. Canon PowerShot G11 Rear Dial Replacement: stap 13, afbeelding 1 van 1
    • Remove the dial from the case completely.
Conclusie
Dustin Brinegar
688 Reputatie
4 handleidingen geschreven
USF Tampa, Team 5-6, Brown Winter 2015 Lid van USF Tampa, Team 5-6, Brown Winter 2015
USFT-BROWN-W15S5G6
3 Leden
6 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 27
Altijd: 2,145
