Inleiding
If the viewfinder wheel on your Canon PowerShot G1 X is broken, use this guide to replace the viewfinder wheel.
The viewfinder wheel is used to adjust the zoom level of the viewfinder. Depending on what part of the wheel is broken the wheel can either spin freely without changing the zoom or not move at all.
Before using this guide, check if debris is preventing the viewfinder zoom wheel from spinning. Use a toothpick or a Q-tip to remove the debris. If the debris cannot be removed follow this guide to remove the viewfinder zoom wheel and clear all the debris.
Make sure to power off your camera completely and disconnect from power before starting this guide.
Wat je nodig hebt
To begin removing the back camera casing, unscrew the Phillips screw underneath the panel covering the USB connections on the side of the camera. Use a Phillips Head 00 screwdriver for this screw.
Remove the screw located directly beneath the USB cover located in the second photo. Use a Phillips Head 00 screwdriver for this screw.
Locate the view finder zoom on the back of the camera.
Remove the screw using a Phillips #000 screwdriver.
To remove the viewfinder wheel, pull it to the left and away from the camera.
Één andere persoon heeft deze handleiding voltooid.
Één opmerking
Do you guys know where I could get the aperture len flex for this model? Thank you!
