Inleiding
Before starting this guide it is important to know that the screwdriver used on each screw is a Phillips #00 screwdriver. It is imperative to keep track of every screw, and to know where each screw was located.
Wat je nodig hebt
To begin removing the back camera casing, unscrew the Phillips screw underneath the panel covering the USB connections on the side of the camera. Use a Phillips Head 00 screwdriver for this screw.
Remove the screw located directly beneath the USB cover located in the second photo. Use a Phillips Head 00 screwdriver for this screw.
Remove the two screws above the buttons followed by the screw on the bottom, using a Phillips #00 screwdriver.
Remove the two screws on the front casing using a Phillips #00 screwdriver.
