Ga door naar hoofdinhoud
Canon PowerShot G1 X Mark II Motherboard Replacement
Wat je nodig hebt
  1. Canon PowerShot G1 X Mark II Motherboard Replacement, Battery: stap 1, afbeelding 1 van 3 Canon PowerShot G1 X Mark II Motherboard Replacement, Battery: stap 1, afbeelding 2 van 3 Canon PowerShot G1 X Mark II Motherboard Replacement, Battery: stap 1, afbeelding 3 van 3
    • Locate the battery housing cover on the bottom of your camera.
    • Place a finger on the textured portion of the battery housing cover.
    • Slide the cover in the direction that the arrow is pointing.
  2. Canon PowerShot G1 X Mark II Motherboard Replacement: stap 2, afbeelding 1 van 2 Canon PowerShot G1 X Mark II Motherboard Replacement: stap 2, afbeelding 2 van 2
    • Use your finger to pivot the orange tab away from the battery.
  3. Canon PowerShot G1 X Mark II Motherboard Replacement: stap 3, afbeelding 1 van 1
    • Pull the battery out of the housing with your fingers.
  4. Canon PowerShot G1 X Mark II Motherboard Replacement, Motherboard: stap 4, afbeelding 1 van 2 Canon PowerShot G1 X Mark II Motherboard Replacement, Motherboard: stap 4, afbeelding 2 van 2
    • Remove the two 4mm Hex screws that connect the grip to the camera with a Hex head screwdriver.
    • Remove the two Phillips screws to the left of the hex screws with a Phillips head screwdriver:
    • One 2mm screw
    • One 3mm screw
    • Remove the grip from the front of the camera by pulling it away from the lens and then away from the camera.
  5. Canon PowerShot G1 X Mark II Motherboard Replacement: stap 5, afbeelding 1 van 1
    • Remove the following three Philips screws from the flash release side of the camera with a Philips Head screwdriver:
    • One 2.5mm screw
    • One 4.5mm screw
    • One 1.75mm screw
  6. Canon PowerShot G1 X Mark II Motherboard Replacement: stap 6, afbeelding 1 van 1
    • Remove the following three Philips screws from the bottom of the camera with a Philips Head screwdriver:
    • One 3.25mm screw
    • One 2.5mm screw
    • One 2.75mm screw
  7. Canon PowerShot G1 X Mark II Motherboard Replacement: stap 7, afbeelding 1 van 2 Canon PowerShot G1 X Mark II Motherboard Replacement: stap 7, afbeelding 2 van 2
    • Rotate the LCD screen away from the camera.
  8. Canon PowerShot G1 X Mark II Motherboard Replacement: stap 8, afbeelding 1 van 1
    • Remove the following four Phillips screws securing the back panel with a Philips Head screwdriver:
    • Two 3 mm screws
    • One 2mm screw
    • One 2.5 mm screw
  9. Canon PowerShot G1 X Mark II Motherboard Replacement: stap 9, afbeelding 1 van 1
    • Lift the back casing up far enough to expose the ribbon cables.
  10. Canon PowerShot G1 X Mark II Motherboard Replacement: stap 10, afbeelding 1 van 2 Canon PowerShot G1 X Mark II Motherboard Replacement: stap 10, afbeelding 2 van 2
    • Use a plastic spudger to gently release the locking tab holding the ribbon cable, closest to the edge of the camera, in place.
    • Repeat this process for the second ribbon cable to the right.
    • Carefully lift the back casing away from the camera.
  11. Canon PowerShot G1 X Mark II Motherboard Replacement: stap 11, afbeelding 1 van 1
  12. Canon PowerShot G1 X Mark II Motherboard Replacement: stap 12, afbeelding 1 van 2 Canon PowerShot G1 X Mark II Motherboard Replacement: stap 12, afbeelding 2 van 2
    • Remove the five Phillips screws that are attached to the copper plate with a Philips Head screwdriver:
    • Two 3mm screws
    • Two 1.5mm screws
    • One 4mm screw
    • Lift the copper plate away from the camera.
  13. Canon PowerShot G1 X Mark II Motherboard Replacement: stap 13, afbeelding 1 van 3 Canon PowerShot G1 X Mark II Motherboard Replacement: stap 13, afbeelding 2 van 3 Canon PowerShot G1 X Mark II Motherboard Replacement: stap 13, afbeelding 3 van 3
    • Remove the following three Phillips screws securing the silver plate with a Philips Head screwdriver:
    • Two 2.9mm screws on the front of the camera
    • One 1.8mm screw on the bottom of the camera
    • Lift the silver plate away from the camera.
  14. Canon PowerShot G1 X Mark II Motherboard Replacement: stap 14, afbeelding 1 van 2 Canon PowerShot G1 X Mark II Motherboard Replacement: stap 14, afbeelding 2 van 2
    • Use the plastic spudger to lift up both sides of the ribbon cable from its connector pins.
    • The male end is on the left and the female end is on the right. The right side of the cable is notched.
  15. Canon PowerShot G1 X Mark II Motherboard Replacement: stap 15, afbeelding 1 van 3 Canon PowerShot G1 X Mark II Motherboard Replacement: stap 15, afbeelding 2 van 3 Canon PowerShot G1 X Mark II Motherboard Replacement: stap 15, afbeelding 3 van 3
    • Use the flat end of the plastic spudger to rotate the black plastic locking tab towards the ribbon cable.
    • Insert the pointed end of the plastic spudger into a small hole on the side of the ribbon cable and pull the ribbon cable out of its housing.
    • Use the flat end of the plastic spudger to pry the ribbon cable connector from the motherboard.
    • Both ribbon cables should be removed after this step.
  16. Canon PowerShot G1 X Mark II Motherboard Replacement: stap 16, afbeelding 1 van 2 Canon PowerShot G1 X Mark II Motherboard Replacement: stap 16, afbeelding 2 van 2
    • Release the flash by sliding the flash release towards the lens.
    • The flash release is located on the side of the camera closest to the lens.
  17. Canon PowerShot G1 X Mark II Motherboard Replacement: stap 17, afbeelding 1 van 2 Canon PowerShot G1 X Mark II Motherboard Replacement: stap 17, afbeelding 2 van 2
    • Remove the following two Phillips screws from the flash cavity with a Philips Head screwdriver:
    • Remove the 2mm screw to the right of the flash.
    • Remove the 2.5mm screw to the left of the flash.
  18. Canon PowerShot G1 X Mark II Motherboard Replacement: stap 18, afbeelding 1 van 2 Canon PowerShot G1 X Mark II Motherboard Replacement: stap 18, afbeelding 2 van 2
    • Remove the 2.5mm Phillips screw from the front plate with a Phillips head screwdriver.
    • Pull up on the top portion of the camera to separate the top casing from the camera body.
    • Make sure the flash is up. Otherwise the top casing will not release.
  19. Canon PowerShot G1 X Mark II Motherboard Replacement: stap 19, afbeelding 1 van 2 Canon PowerShot G1 X Mark II Motherboard Replacement: stap 19, afbeelding 2 van 2
    • Remove the 3.5mm Phillips screw from the grey tab on the top of the camera with a Philips Head screwdriver.
    • Rotate the camera so the back panel is facing you.
    • Remove the 1.4mm Phillips screw from the sliver tab near the top of the camera with a Philips Head screwdriver.
  20. Canon PowerShot G1 X Mark II Motherboard Replacement: stap 20, afbeelding 1 van 2 Canon PowerShot G1 X Mark II Motherboard Replacement: stap 20, afbeelding 2 van 2
    • Use the flat end of the plastic spudger to release the plastic retaining clip on the side plate closest to the lens.
    • Rotate the side plate closest to the lens toward the lens of the camera and then pull the plate away from the camera.
  21. Canon PowerShot G1 X Mark II Motherboard Replacement: stap 21, afbeelding 1 van 3 Canon PowerShot G1 X Mark II Motherboard Replacement: stap 21, afbeelding 2 van 3 Canon PowerShot G1 X Mark II Motherboard Replacement: stap 21, afbeelding 3 van 3
    Gereedschap gebruikt in deze stap:
    • Release the plastic locking tab of the upper ribbon cable with the plastic spudger.
    • Pull the top ribbon cable from its mount with the fine tip metal tweezers.
    • Remove the bottom ribbon cable with the fine tip metal tweezers by pulling it toward the flash switch side of the camera.
    • The bottom ribbon cable does not have a locking tab; it simply slides in and out.
  22. Canon PowerShot G1 X Mark II Motherboard Replacement: stap 22, afbeelding 1 van 1
    • Pull the front plate off the camera body.
    • It should slide off easily. If it does not, ensure that all screws and ribbon cables from previous steps have been removed or disconnected.
  23. Canon PowerShot G1 X Mark II Motherboard Replacement: stap 23, afbeelding 1 van 1
    • Remove the rubber dust cover from the camera by moving the hooks away from the three prongs holding them in place and then pulling the cover away from the camera.
  24. Canon PowerShot G1 X Mark II Motherboard Replacement: stap 24, afbeelding 1 van 2 Canon PowerShot G1 X Mark II Motherboard Replacement: stap 24, afbeelding 2 van 2
    • Remove the following two Phillips screws from the side of the camera with the three connector ports with a Phillips head screwdriver:
    • One 2.5mm screw
    • One 3.3mm screw
    • Pull the metal shield away from the camera.
  25. Canon PowerShot G1 X Mark II Motherboard Replacement: stap 25, afbeelding 1 van 3 Canon PowerShot G1 X Mark II Motherboard Replacement: stap 25, afbeelding 2 van 3 Canon PowerShot G1 X Mark II Motherboard Replacement: stap 25, afbeelding 3 van 3
    • Use the plastic spudger to remove the ribbon cable from the motherboard by placing the spudger under the ribbon cable connector and pulling up.
    • Remove the 2.8mm screw from the motherboard.
    • Do not try to remove the motherboard from the camera yet.
    • Carefully rotate the motherboard upward.
    • Use the plastic spudger to remove the ribbon cable from the bottom of the motherboard by placing the spudger under the ribbon cable connector and pulling up.
  26. Canon PowerShot G1 X Mark II Motherboard Replacement: stap 26, afbeelding 1 van 1
    • Lift the motherboard away from the camera.
Conclusie
4 andere personen hebben deze handleiding voltooid.
Ryan Dunn
578 Reputatie
3 handleidingen geschreven
Cal Poly, Team 70-2, Forte Winter 2016 Lid van Cal Poly, Team 70-2, Forte Winter 2016
CPSU-FORTE-W16S70G2
4 Leden
4 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 25
Afgelopen 30 dagen: 30
Altijd: 1,089
