Ga door naar hoofdinhoud
Canon PowerShot ELPH330 HS Camera Power/Shutter Button Panel Replacement
Wat je nodig hebt
  1. Canon PowerShot ELPH330 HS Camera Power/Shutter Button Panel Replacement, Power/Shutter Button Panel: stap 1, afbeelding 1 van 2 Canon PowerShot ELPH330 HS Camera Power/Shutter Button Panel Replacement, Power/Shutter Button Panel: stap 1, afbeelding 2 van 2
    • On the top-center of your device, turn off the camera by pressing the power button.
    • Put your finger on the battery door and slide the battery door to the right to open it.
    • Push the release button downward and it will release the battery.
  2. Canon PowerShot ELPH330 HS Camera Power/Shutter Button Panel Replacement: stap 2, afbeelding 1 van 1
    • Use the Phillips #00 screwdriver to remove the screws.
  3. Canon PowerShot ELPH330 HS Camera Power/Shutter Button Panel Replacement: stap 3, afbeelding 1 van 1
    • Remove the two 4.0mm screws on the bottom of the camera located near the battery door using a Phillips #00 screwdriver.
  4. Canon PowerShot ELPH330 HS Camera Power/Shutter Button Panel Replacement: stap 4, afbeelding 1 van 1
    • At the bottom of the camera next to the battery door, remove two more screws using the Phillips #00 screwdriver.
  5. Canon PowerShot ELPH330 HS Camera Power/Shutter Button Panel Replacement: stap 5, afbeelding 1 van 1
    • To remove the back portion of the camera case, use your fingers to carefully pry the case apart at the seam.
  6. Canon PowerShot ELPH330 HS Camera Power/Shutter Button Panel Replacement: stap 6, afbeelding 1 van 2 Canon PowerShot ELPH330 HS Camera Power/Shutter Button Panel Replacement: stap 6, afbeelding 2 van 2
    • On the motherboard there should be a white port. Using the spudger, disconnect it from the motherboard.
  7. Canon PowerShot ELPH330 HS Camera Power/Shutter Button Panel Replacement: stap 7, afbeelding 1 van 1
    • Follow the green and white wire. There is a gray piece of rubber holding the button into place. Remove it with the spudger.
  8. Canon PowerShot ELPH330 HS Camera Power/Shutter Button Panel Replacement: stap 8, afbeelding 1 van 1
    • Lift the panel off from the top of the camera with your hands.
Conclusie
Michelle Ngo
595 Reputatie
3 handleidingen geschreven
UW Tacoma, Team S1-G3, Liner Summer 2019 Lid van UW Tacoma, Team S1-G3, Liner Summer 2019
UWT-LINER-SU19S1G3
4 Leden
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 13
Altijd: 302
