Ga door naar hoofdinhoud
Canon PowerShot ELPH330 HS Camera Case Replacement
Wat je nodig hebt
  1. Canon PowerShot ELPH330 HS Camera Case Replacement, Camera Case: stap 1, afbeelding 1 van 2 Canon PowerShot ELPH330 HS Camera Case Replacement, Camera Case: stap 1, afbeelding 2 van 2
    • On the top-center of your device, turn off the camera by pressing the power button.
    • Put your finger on the battery door and slide the battery door to the right which will then open the door.
    • Push the release button downward and it will release the battery.
  2. Canon PowerShot ELPH330 HS Camera Case Replacement: stap 2, afbeelding 1 van 1
    • Use the Phillips #00 screwdriver to remove the two screws.
  3. Canon PowerShot ELPH330 HS Camera Case Replacement: stap 3, afbeelding 1 van 1
    • Remove two more screws using the Phillips #00 screwdriver.
  4. Canon PowerShot ELPH330 HS Camera Case Replacement: stap 4, afbeelding 1 van 1
    • On the lower right side of the camera case, remove the single screw using Phillips #00 screwdriver.
    • On the upper right side of the camera, remove the HDMI A/V out port.
    • Beneath the port cover, remove the screw using the same Phillips #00 screwdriver.
  5. Canon PowerShot ELPH330 HS Camera Case Replacement: stap 5, afbeelding 1 van 1
    • Using your fingers, carefully pry the case apart at the seam.
Conclusie
Michelle Ngo
595 Reputatie
3 handleidingen geschreven
UW Tacoma, Team S1-G3, Liner Summer 2019 Lid van UW Tacoma, Team S1-G3, Liner Summer 2019
UWT-LINER-SU19S1G3
4 Leden
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 7
Afgelopen 30 dagen: 12
Altijd: 178
