Ga door naar hoofdinhoud
Canon PowerShot ELPH330 HS Camera Repair LCD Screen Replacement
Wat je nodig hebt
  1. Canon PowerShot ELPH330 HS Camera  Repair LCD Screen  Replacement, LCD Screen: stap 1, afbeelding 1 van 2 Canon PowerShot ELPH330 HS Camera  Repair LCD Screen  Replacement, LCD Screen: stap 1, afbeelding 2 van 2
    • Turn off your camera.
    • Remove the battery.
    • Slide the battery door open with the rubber pad on the bottom right side of the camera.
    • Remove the battery by pushing down on the release button.
  2. Canon PowerShot ELPH330 HS Camera  Repair LCD Screen  Replacement: stap 2, afbeelding 1 van 1
    • Remove the two screws on the left side with a Phillips #00 screwdriver.
  3. Canon PowerShot ELPH330 HS Camera  Repair LCD Screen  Replacement: stap 3, afbeelding 1 van 1
    • Remove the two screws on the bottom of the camera with a Phillips #00 screwdriver.
  4. Canon PowerShot ELPH330 HS Camera  Repair LCD Screen  Replacement: stap 4, afbeelding 1 van 1
    • Remove the two screws on the right side with a Phillips #00 screwdriver.
  5. Canon PowerShot ELPH330 HS Camera  Repair LCD Screen  Replacement: stap 5, afbeelding 1 van 1
    • Using your fingers, carefully pry the case apart at the seam.
  6. Canon PowerShot ELPH330 HS Camera  Repair LCD Screen  Replacement: stap 6, afbeelding 1 van 2 Canon PowerShot ELPH330 HS Camera  Repair LCD Screen  Replacement: stap 6, afbeelding 2 van 2
    • Flip the camera over so that the lens is facing you.
    • Disconnect the highlighted port from the motherboard.
  7. Canon PowerShot ELPH330 HS Camera  Repair LCD Screen  Replacement: stap 7, afbeelding 1 van 2 Canon PowerShot ELPH330 HS Camera  Repair LCD Screen  Replacement: stap 7, afbeelding 2 van 2
    • Remove the bracket around the LCD screen.
  8. Canon PowerShot ELPH330 HS Camera  Repair LCD Screen  Replacement: stap 8, afbeelding 1 van 1
    • Using the spudger, carefully pry the top to remove the LCD screen.
Conclusie
Michelle Ngo
595 Reputatie
3 handleidingen geschreven
UW Tacoma, Team S1-G3, Liner Summer 2019 Lid van UW Tacoma, Team S1-G3, Liner Summer 2019
UWT-LINER-SU19S1G3
4 Leden
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 8
Altijd: 822
