Ga door naar hoofdinhoud
Canon PowerShot ELPH 310 HS LCD Screen Replacement
Wat je nodig hebt
  1. Canon PowerShot ELPH 310 HS LCD Screen Replacement, External Panels: stap 1, afbeelding 1 van 1
    • Use the Phillips #000 screwdriver from the iFixit tool kit to unscrew the two image stabilizer panel’s 2 mm Phillips head screws.
    • Using your hands, remove the image stabilizer panel.
  2. Canon PowerShot ELPH 310 HS LCD Screen Replacement: stap 2, afbeelding 1 van 2 Canon PowerShot ELPH 310 HS LCD Screen Replacement: stap 2, afbeelding 2 van 2
    • Unscrew the two 4 mm Phillips head screws from the bottom side of the camera.
  3. Canon PowerShot ELPH 310 HS LCD Screen Replacement: stap 3, afbeelding 1 van 2 Canon PowerShot ELPH 310 HS LCD Screen Replacement: stap 3, afbeelding 2 van 2
    • Using your hand, open the battery portal located on the bottom left of the camera. The screw is in the bottom left of the battery portal.
    • Unscrew the hidden 4mm Phillips head screw inside the battery portal.
  4. Canon PowerShot ELPH 310 HS LCD Screen Replacement: stap 4, afbeelding 1 van 2 Canon PowerShot ELPH 310 HS LCD Screen Replacement: stap 4, afbeelding 2 van 2
    • Remove the HDMI side panel with your hands.
    • Unscrew the four 4 mm Phillips head screws from the inside of the camera.
  5. Canon PowerShot ELPH 310 HS LCD Screen Replacement: stap 5, afbeelding 1 van 1
    • The back side of the camera should pop off or be removed by hand.
  6. Canon PowerShot ELPH 310 HS LCD Screen Replacement: stap 6, afbeelding 1 van 2 Canon PowerShot ELPH 310 HS LCD Screen Replacement: stap 6, afbeelding 2 van 2
    • Unscrew the one 3 mm Phillips head screw on the top of the camera.
  7. Canon PowerShot ELPH 310 HS LCD Screen Replacement: stap 7, afbeelding 1 van 1
    • Manually remove the front panel from the camera.
  8. Canon PowerShot ELPH 310 HS LCD Screen Replacement, LCD Screen: stap 8, afbeelding 1 van 2 Canon PowerShot ELPH 310 HS LCD Screen Replacement, LCD Screen: stap 8, afbeelding 2 van 2
    • Using your hands, remove the metal piece (surrounding the right side of the screen) from the right side of the camera.
  9. Canon PowerShot ELPH 310 HS LCD Screen Replacement: stap 9, afbeelding 1 van 1
    • Using your hands, lift up the screen.
    • The screen is fragile!
  10. Canon PowerShot ELPH 310 HS LCD Screen Replacement: stap 10, afbeelding 1 van 3 Canon PowerShot ELPH 310 HS LCD Screen Replacement: stap 10, afbeelding 2 van 3 Canon PowerShot ELPH 310 HS LCD Screen Replacement: stap 10, afbeelding 3 van 3
    • The strip tears easily!
    • Manually lift the shutter button plate and remove the white ZIF connector, which is the white clasp underneath.
    • On the front of the camera, using your fingers, undo the orange ribbon from the gray clasp and pull the ribbon through the shutter deck.
Conclusie
Kadie Aldridge
213 Reputatie
2 handleidingen geschreven
1Gids Commentaar
Part number for the screen replacement
Jeff Herider - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 7
Altijd: 1,280
