Ga door naar hoofdinhoud
Canon PowerShot ELPH 300HS Flash Replacement
Wat je nodig hebt
    • Before you begin taking apart your device, the first, and MOST IMPORTANT STEPS are to:
    • Turn off your camera.
    • Remove the battery to prevent risk of shock.
  1. Canon PowerShot ELPH 300HS Flash Replacement, Remove the Battery: stap 2, afbeelding 1 van 2 Canon PowerShot ELPH 300HS Flash Replacement, Remove the Battery: stap 2, afbeelding 2 van 2
    • Turn off your camera by pressing the power button, located on the top-center of the device.
    • Locate the battery door on the bottom right area of the camera case.
    • Place your finger firmly on the black rubber pad on the battery door and slide the door to the right to open it.
    • Locate the orange battery release button beneath the battery door.
    • Slide the battery release button downward to release the battery.
  2. Canon PowerShot ELPH 300HS Flash Replacement, Left Side Screws: stap 3, afbeelding 1 van 1
    • Be careful when removing screws, as they are stripped easily.
    • Remove the two screws located on the left side of the camera case, using the Phillips screwdriver #00 (2.0 mm).
  3. Canon PowerShot ELPH 300HS Flash Replacement, Bottom Screws: stap 4, afbeelding 1 van 1
    • Remove the two screws on the bottom of the camera located near the battery door (Phillips #00 screwdriver) (4.0 mm).
  4. Canon PowerShot ELPH 300HS Flash Replacement, Right Side Screws: stap 5, afbeelding 1 van 1
    • Remove the screw located on the lower right side of the camera case (Phillips #00 screwdriver) (4.0 mm).
    • Remove the HDMI A/V out port cover located on the upper right side of the camera.
    • Remove the screw located just beneath the port cover removed in step 2. (Phillips #00 screwdriver) (2.0 mm).
  5. Canon PowerShot ELPH 300HS Flash Replacement: stap 6, afbeelding 1 van 1
    • Remove the back portion of the camera case to reveal the screw located on the top of the case.
    • Remove the screw from the top of camera case, located next to the shutter button (Phillips #00 screwdriver) (1.5 mm).
  6. Canon PowerShot ELPH 300HS Flash Replacement, Remove the Case from the Camera: stap 7, afbeelding 1 van 3 Canon PowerShot ELPH 300HS Flash Replacement, Remove the Case from the Camera: stap 7, afbeelding 2 van 3 Canon PowerShot ELPH 300HS Flash Replacement, Remove the Case from the Camera: stap 7, afbeelding 3 van 3
    • Carefully pry the case apart at the seem, using your fingers.
    • Be careful not to over bend the small metal projections located along the seams. These aid in holding the case together.
    • Be careful not to allow dust or other particles to settle inside of the camera while the case is detached. This can cause functional issues in the future.
  7. Canon PowerShot ELPH 300HS Flash Replacement, LCD Screen: stap 8, afbeelding 1 van 2 Canon PowerShot ELPH 300HS Flash Replacement, LCD Screen: stap 8, afbeelding 2 van 2
    • Disconnect the copper ribbon next to the blue port on the motherboard
    • To remove ribbon cable, gently lift the black tab with a flat head screwdriver. Lift from the top of the camera towards the bottom. This releases the cable. Be gentle, as the cables are fragile.
  8. Canon PowerShot ELPH 300HS Flash Replacement: stap 10, afbeelding 1 van 3 Canon PowerShot ELPH 300HS Flash Replacement: stap 10, afbeelding 2 van 3 Canon PowerShot ELPH 300HS Flash Replacement: stap 10, afbeelding 3 van 3
    • Remove the L shaped bracket around the top and right side of the LCD screen
  9. Canon PowerShot ELPH 300HS Flash Replacement: stap 11, afbeelding 1 van 3 Canon PowerShot ELPH 300HS Flash Replacement: stap 11, afbeelding 2 van 3 Canon PowerShot ELPH 300HS Flash Replacement: stap 11, afbeelding 3 van 3
    • Insert the flat side of the spudger tool carefully on the top of the LCD screen and lift the screen free
  10. Canon PowerShot ELPH 300HS Flash Replacement, Flash: stap 12, afbeelding 1 van 2 Canon PowerShot ELPH 300HS Flash Replacement, Flash: stap 12, afbeelding 2 van 2
    • Carefully remove the large copper ribbon on the front of the camera (attached with adhesive pads)
  11. Canon PowerShot ELPH 300HS Flash Replacement: stap 13, afbeelding 1 van 2 Canon PowerShot ELPH 300HS Flash Replacement: stap 13, afbeelding 2 van 2
    • Remove the ribbon wire attached at the bottom right corner of the front of the camera. You do NOT need to remove this from the motherboard.
  12. Canon PowerShot ELPH 300HS Flash Replacement: stap 14, afbeelding 1 van 3 Canon PowerShot ELPH 300HS Flash Replacement: stap 14, afbeelding 2 van 3 Canon PowerShot ELPH 300HS Flash Replacement: stap 14, afbeelding 3 van 3
    • Unscrew the screw on the circuit board on the front of the camera (length 3.5 mm)
    • Unscrew the screw on the lower left part of the silver part of the back under where the LCD screen was.
    • Unscrew the screw on the top of the silver part of the back
  13. Canon PowerShot ELPH 300HS Flash Replacement: stap 15, afbeelding 1 van 3 Canon PowerShot ELPH 300HS Flash Replacement: stap 15, afbeelding 2 van 3 Canon PowerShot ELPH 300HS Flash Replacement: stap 15, afbeelding 3 van 3
    • Lift the flash housing up and forward from the top of the camera to carefully remove
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Kathryn Van Susante
667 Reputatie
5 handleidingen geschreven
Michigan Tech, Team 5-6, Lauer Spring 2014 Lid van Michigan Tech, Team 5-6, Lauer Spring 2014
MTU-LAUER-S14S5G6
3 Leden
6 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 15
Altijd: 1,038
