Ga door naar hoofdinhoud
Canon PowerShot A95 Viewfinder Replacement
Wat je nodig hebt
  1. Canon PowerShot A95 Viewfinder Replacement, Viewfinder: stap 1, afbeelding 1 van 2 Canon PowerShot A95 Viewfinder Replacement, Viewfinder: stap 1, afbeelding 2 van 2
    • Locate the black “BATT OPEN” button on the underside of the camera.
    • Slide the black “BATT OPEN” button to the right.
    • Remove four AA batteries from the device.
  2. Canon PowerShot A95 Viewfinder Replacement: stap 2, afbeelding 1 van 1
    • Locate and remove three screws on the underside of the camera (3x small Phillips head).
    • Keep all screws separated by step and in a place where they will not be lost.
    • Tip: a jewelry tray can be helpful for keeping all the screws secure and separated.
  3. Canon PowerShot A95 Viewfinder Replacement: stap 3, afbeelding 1 van 1
    • Locate and remove two screws on the same side of the camera as the marked A/V port (2x small Phillips head).
  4. Canon PowerShot A95 Viewfinder Replacement: stap 4, afbeelding 1 van 2 Canon PowerShot A95 Viewfinder Replacement: stap 4, afbeelding 2 van 2
    • Using the blue plastic opening tool, remove the plastic covering you just removed screws from on the left side of camera.
    • Gently pull up around edges until the plastic flap inside is pulled out and the piece swings upward (piece should pull free).
  5. Canon PowerShot A95 Viewfinder Replacement: stap 5, afbeelding 1 van 1
    • Remove indicated screw holding front of camera in place.
  6. Canon PowerShot A95 Viewfinder Replacement: stap 6, afbeelding 1 van 3 Canon PowerShot A95 Viewfinder Replacement: stap 6, afbeelding 2 van 3 Canon PowerShot A95 Viewfinder Replacement: stap 6, afbeelding 3 van 3
    • Push against the memory card cover in order to pull it outward toward you to reveal a screw underneath.
    • Remove this screw (Phillips head).
  7. Canon PowerShot A95 Viewfinder Replacement: stap 7, afbeelding 1 van 1
    • Re-open the battery cover. Locate and remove the three screws under the battery cover (3x small, long Phillips head).
    • Tip: using a magnetic screwdriver is very helpful, as the screws are difficult to reach.
  8. Canon PowerShot A95 Viewfinder Replacement: stap 8, afbeelding 1 van 1
    • Locate and lift the shutter button, speaker, and option wheel from the top of the camera.
    • Note: DO NOT pull too hard as there is a plug connecting the speaker to the camera.
    • The memory card cover will pop off in this process.
    • Note the original location next to the loose pieces of hardware. This piece will remain attached to the device, so do not try to fully detach it.
  9. Canon PowerShot A95 Viewfinder Replacement: stap 9, afbeelding 1 van 2 Canon PowerShot A95 Viewfinder Replacement: stap 9, afbeelding 2 van 2
    • Locate and press the button on the lower left corner of the lens.
    • Separate the back casing from the front casing of the camera.
    • Removing the casing may require the use of a spudger.
  10. Canon PowerShot A95 Viewfinder Replacement: stap 10, afbeelding 1 van 2 Canon PowerShot A95 Viewfinder Replacement: stap 10, afbeelding 2 van 2
    • Twist the LCD screen so it is perpendicular to the camera and snap the back casing off.
    • This piece will remain attached to the device, so do not try to fully detach it.
  11. Canon PowerShot A95 Viewfinder Replacement: stap 11, afbeelding 1 van 2 Canon PowerShot A95 Viewfinder Replacement: stap 11, afbeelding 2 van 2
    • Carefully jiggle the viewfinder until it comes loose from the camera.
Conclusie
Elizabeth Kisner
101 Reputatie
1 Handleiding geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 22
Altijd: 2,174
