Ga door naar hoofdinhoud
Canon PowerShot A80 LCD Screen Replacement
Wat je nodig hebt
  1. Canon PowerShot A80 LCD Screen Replacement, LCD Screen: stap 1, afbeelding 1 van 1
    • Using a Phillips #00 screwdriver, remove the two 2.9 mm screws on the side of the LCD screen.
  2. Canon PowerShot A80 LCD Screen Replacement: stap 2, afbeelding 1 van 2 Canon PowerShot A80 LCD Screen Replacement: stap 2, afbeelding 2 van 2
    • Using a Phillips #00 screwdriver, remove the 2.9 mm screws on the other side of the screen to separate the front and back covers.
    • To access the second screw, rotate the screen 90° so that it faces upwards.
  3. Canon PowerShot A80 LCD Screen Replacement: stap 3, afbeelding 1 van 3 Canon PowerShot A80 LCD Screen Replacement: stap 3, afbeelding 2 van 3 Canon PowerShot A80 LCD Screen Replacement: stap 3, afbeelding 3 van 3
    • Gently remove the front and back covers from the screen.
    • Peel back the plastic circuit cover.
  4. Canon PowerShot A80 LCD Screen Replacement: stap 4, afbeelding 1 van 1
    • Pull the screen away from the base.
    • This will take some force, but remember to handle with care.
    • If a small metal piece between the screen cover and the screen falls out during repair, replace it with the rounded corners facing away from the screen during reassembly.
  5. Canon PowerShot A80 LCD Screen Replacement: stap 5, afbeelding 1 van 1
    • Unplug the ribbon cable connected to the circuit board latch.
Conclusie
4 andere personen hebben deze handleiding voltooid.
konrad
220 Reputatie
3 handleidingen geschreven
Cal Poly, Team 7-31, Regan Winter 2011 Lid van Cal Poly, Team 7-31, Regan Winter 2011
CPSU-REGAN-W11S7G31
6 Leden
12 handleidingen geschreven
Één opmerking
MY screen is dark after touched water, do I need to change this screen? Where can I buy this screen? How much?
Thank you for the guidance.
jennifer
yu123xi@yahoo.com
yu123xi - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 22
Altijd: 4,098
