Ga door naar hoofdinhoud
Repareer je spullen
Recht op reparatie
Winkel
Inleiding
To isolate the LCD screen, one needs to be gentle with separating parts and removing screws from the camera.
Onderdelen
Geen onderdelen opgegeven.
  1. Unscrew the two 2.9 mm screws on the side of the screen which connect the front and back cover of the LCD screen using a #00 screwdriver.
    • Unscrew the two 2.9 mm screws on the side of the screen which connect the front and back cover of the LCD screen using a #00 screwdriver.
  2. Unscrew the 2.9 mm side screws on the other side of the screen using a #00 screwdriver. These also hold the screen covers together. To access the second screw, rotate the screen.
    • Unscrew the 2.9 mm side screws on the other side of the screen using a #00 screwdriver. These also hold the screen covers together.
    • To access the second screw, rotate the screen.
  3. OPEN ALLE TABBLADEN
    RAM-upgradekits voor Mac
    Koop kits
    Genoeg RAM
    voor al je tabbladen
    Koop kits
  4. Gently separate the front and back covers of the screen. Peel back the plastic circuit cover. Peel back the plastic circuit cover.
    • Gently separate the front and back covers of the screen.
    • Peel back the plastic circuit cover.
  5. Gently pull the screen away from the base.
    • Gently pull the screen away from the base.
    • A small metal piece between the screen cover and the screen may fall out during repair. Remember to replace it with the rounded corners facing away from the screen during reassembly.
    • This takes a little force.
  6. Unplug the ribbon cable connecting the screen to the circuit board.
    • Unplug the ribbon cable connecting the screen to the circuit board.
Conclusie
3 andere personen hebben deze handleiding voltooid.
konrad
217 Reputatie
3 handleidingen geschreven
Cal Poly, Team 7-31, Regan Winter 2011 Lid van Cal Poly, Team 7-31, Regan Winter 2011
CPSU-REGAN-W11S7G31
6 Leden
12 handleidingen geschreven
Één commentaar
MY screen is dark after touched water, do I need to change this screen? Where can I buy this screen? How much?
Thank you for the guidance.
jennifer
yu123xi@yahoo.com
yu123xi - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 9
Altijd: 3,478
