Ga door naar hoofdinhoud
Canon PowerShot A80 Internal Battery Replacement
Wat je nodig hebt
  1. Canon PowerShot A80 Internal Battery Replacement, Back Cover: stap 1, afbeelding 1 van 1
    • Remove the three Phillips #00 screws from the bottom of the camera.
  2. Canon PowerShot A80 Internal Battery Replacement: stap 2, afbeelding 1 van 2 Canon PowerShot A80 Internal Battery Replacement: stap 2, afbeelding 2 van 2
    • Open the door to the CompactFlash memory card slot by sliding it towards you and swinging it open.
    • Remove the memory card if it is still in the camera.
    • Use the Phillips #00 screwdriver to remove the single screw underneath the memory card slot door.
  3. Canon PowerShot A80 Internal Battery Replacement: stap 3, afbeelding 1 van 1
    • Remove the Phillips #00 screw located inside the top of the memory card compartment.
  4. Canon PowerShot A80 Internal Battery Replacement: stap 4, afbeelding 1 van 2 Canon PowerShot A80 Internal Battery Replacement: stap 4, afbeelding 2 van 2
    • Open the battery compartment door at the bottom of the camera by sliding the latch to the right and then sliding the door down.
    • Remove the batteries from the compartment.
    • Remove the three Phillips #00 screws located inside the battery compartment.
    • The screw on the left is longer than the other two.
  5. Canon PowerShot A80 Internal Battery Replacement: stap 5, afbeelding 1 van 1
    • Remove the top lid of the camera.
    • Be cautious of the fragile mylar cable that connects the lid to the main body of the camera.
    • Removing the lid takes a little force. Do this gently. There may be a snapping sound.
    • The door to the memory card compartment will be freed and should be removable now.
    • In other versions of this camera, there is a tab that secures the top from the wrist strap. If yours has this, you won't be able to completely separate the top until you have removed the top screw in Step 8.
    The upper screw from Step 6 must be removed first, ( also fixing top lid )
    micsch4 - Antwoord
  6. Canon PowerShot A80 Internal Battery Replacement: stap 6, afbeelding 1 van 1
    • Remove the two Phillips #00 screws from the side of the camera.
    • Open the small rubber door below this screw that covers the connectors.
  7. Canon PowerShot A80 Internal Battery Replacement: stap 7, afbeelding 1 van 2 Canon PowerShot A80 Internal Battery Replacement: stap 7, afbeelding 2 van 2
    • Open and pivot the LCD screen to its widest open position.
    • Remove the rear cover by pulling it straight away from the body of the camera.
    • When reassembling the camera, remember to replace the screws in the same location from which you removed them. Otherwise, you may damage the camera.
  8. Canon PowerShot A80 Internal Battery Replacement, Internal Battery: stap 8, afbeelding 1 van 2 Canon PowerShot A80 Internal Battery Replacement, Internal Battery: stap 8, afbeelding 2 van 2
    • Unscrew the top 3.9mm, middle 2.7 mm, and bottom 2.9mm screws that hold the metal foundation covering the internal battery.
    • See next photo for zoomed image of the boxed screw.
  9. Canon PowerShot A80 Internal Battery Replacement: stap 9, afbeelding 1 van 1
    • Remove the marked 2.9mm screw shown.
  10. Canon PowerShot A80 Internal Battery Replacement: stap 10, afbeelding 1 van 1
    • Lift open the battery cover and unscrew the 3.8mm screw as shown.
  11. Canon PowerShot A80 Internal Battery Replacement: stap 11, afbeelding 1 van 2 Canon PowerShot A80 Internal Battery Replacement: stap 11, afbeelding 2 van 2
    • Gently lift up the plate as shown.
    • Loosen and gently pry the internal battery with the point blade probe.
Conclusie
4 andere personen hebben deze handleiding voltooid.
konrad
220 Reputatie
3 handleidingen geschreven
Cal Poly, Team 7-31, Regan Winter 2011 Lid van Cal Poly, Team 7-31, Regan Winter 2011
CPSU-REGAN-W11S7G31
6 Leden
12 handleidingen geschreven
2 opmerkingen
Excellent guide. Congratulations.
Bryn Thomas
Wales
Bryn Thomas - Antwoord
What kind of battery is used internally?
Sarah Schmeltz - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 15
Afgelopen 30 dagen: 50
Altijd: 8,297
