Ga door naar hoofdinhoud
Canon PowerShot A75 Batteries Replacement
  1. Canon PowerShot A75 Batteries Replacement, Batteries: stap 1, afbeelding 1 van 1
    • Turn the camera over and locate the "BATT OPEN" sliding switch.
  2. Canon PowerShot A75 Batteries Replacement: stap 2, afbeelding 1 van 3 Canon PowerShot A75 Batteries Replacement: stap 2, afbeelding 2 van 3 Canon PowerShot A75 Batteries Replacement: stap 2, afbeelding 3 van 3
    • Slide the switch to the right.
    • The battery cover should slide down and spring open.
  3. Canon PowerShot A75 Batteries Replacement: stap 3, afbeelding 1 van 3 Canon PowerShot A75 Batteries Replacement: stap 3, afbeelding 2 van 3 Canon PowerShot A75 Batteries Replacement: stap 3, afbeelding 3 van 3
    • Remove the 4 AA batteries.
    • Watch for the orientation of the batteries as they slide out.
    • The battery orientation is shown under the battery flap itself and on a sticker next to the battery flap.
Conclusie
Put in fresh batteries. Gently shut the flap and slide it forward until you hear a click.
Henry Braden Fisk
63 Reputatie
1 Handleiding geschreven
Cal Poly, Team 17-30, Amido Spring 2012 Lid van Cal Poly, Team 17-30, Amido Spring 2012
CPSU-AMIDO-S12S17G30
5 Leden
12 handleidingen geschreven
3 opmerkingen
Hi, there is a problem with my Powershot a75. Whenever I switch it on, it just says change the batteries even though they are either new, or fully charged. Thanks
Harry collier - Antwoord
had same trouble i fix it buy pressing the print button on back next to the disp button it should work then
hot5 - Antwoord
Probably you have change backup battery which is rechargeable and not easy to change. It is close to chargeable outlet.
Maganbhai Patel - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 36
Altijd: 1,778
