Ga door naar hoofdinhoud
Canon PowerShot A630 Front Panel Replacement
Wat je nodig hebt
  1. Canon PowerShot A630 Front Panel Replacement, Front Panel: stap 1, afbeelding 1 van 2 Canon PowerShot A630 Front Panel Replacement, Front Panel: stap 1, afbeelding 2 van 2
    • Open the battery door by sliding the tab on the battery door while pushing the battery door away from the camera.
    • Remove batteries.
  2. Canon PowerShot A630 Front Panel Replacement: stap 2, afbeelding 1 van 2 Canon PowerShot A630 Front Panel Replacement: stap 2, afbeelding 2 van 2
    • Remove the three indicated .2mm screws using a Phillips #00 screwdriver.
    • Gently pull off side-panel to remove it.
  3. Canon PowerShot A630 Front Panel Replacement: stap 3, afbeelding 1 van 1
    • Remove the two indicated .2mm screws using a Phillips #00 screwdriver.
  4. Canon PowerShot A630 Front Panel Replacement: stap 4, afbeelding 1 van 2 Canon PowerShot A630 Front Panel Replacement: stap 4, afbeelding 2 van 2
    • Remove the indicated .2mm screw using a Phillips #00 screwdriver.
    • Remove the three .2mm screws located on the internal side of the top panel within the battery chamber using a Phillips #00 screwdriver.
  5. Canon PowerShot A630 Front Panel Replacement: stap 5, afbeelding 1 van 2 Canon PowerShot A630 Front Panel Replacement: stap 5, afbeelding 2 van 2
    • Open 'DIGITAL A/V OUT' door on camera.
  6. Canon PowerShot A630 Front Panel Replacement: stap 6, afbeelding 1 van 1
    • Grip the sides of the top panel and gently pull to separate the top panel from the camera body.
    • The top panel will not completely detach.
  7. Canon PowerShot A630 Front Panel Replacement: stap 7, afbeelding 1 van 2 Canon PowerShot A630 Front Panel Replacement: stap 7, afbeelding 2 van 2
    • Gently pull the front and back panels apart, and use a Phillips #00 screwdriver to remove the screw connecting the panels.
    • Gripping the top and bottom, gently pull the front panel away from the camera body to remove it.
Conclusie
Kelly Duggan
442 Reputatie
3 handleidingen geschreven
Clemson, Team 2-5, Benson Fall 2014 Lid van Clemson, Team 2-5, Benson Fall 2014
CLEM-BENSON-F14S2G5
4 Leden
18 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 11
Altijd: 745
