Ga door naar hoofdinhoud
Canon PowerShot A620 Shutter Button Replacement
Wat je nodig hebt
  1. Canon PowerShot A620 Shutter Button Replacement, Side Panel: stap 1, afbeelding 1 van 3 Canon PowerShot A620 Shutter Button Replacement, Side Panel: stap 1, afbeelding 2 van 3 Canon PowerShot A620 Shutter Button Replacement, Side Panel: stap 1, afbeelding 3 van 3
    • Unscrew the three Phillips #00 1.6x3mm screws on the side.
    • Lift loose panel from the case.
    • Unscrew the two Phillips #00 1.6x3mm screws that were previously hidden beneath the panel.
  2. Canon PowerShot A620 Shutter Button Replacement, Bottom Panel: stap 2, afbeelding 1 van 1
    • Unscrew the two Phillips #00 1.6x3mm screws on the bottom panel.
  3. Canon PowerShot A620 Shutter Button Replacement, Battery Compartment: stap 3, afbeelding 1 van 1
    • Open the battery door.
    • Unscrew the four Phillips #00 1.6x3mm screws in the battery compartment.
  4. Canon PowerShot A620 Shutter Button Replacement, Terminal Cover: stap 4, afbeelding 1 van 2 Canon PowerShot A620 Shutter Button Replacement, Terminal Cover: stap 4, afbeelding 2 van 2
    • Lift the terminal cover on the side of the camera.
    • Unscrew the three Phillips #00 1.6x3mm screws beneath the terminal cover.
  5. Canon PowerShot A620 Shutter Button Replacement, Top Panel: stap 5, afbeelding 1 van 1
    • Gently pull the top panel to separate it from the case.
    • Although the top panel will now be free from the rest of the case, it will still be attached to the camera by a ribbon cable.
  6. Canon PowerShot A620 Shutter Button Replacement, Front Panel: stap 6, afbeelding 1 van 2 Canon PowerShot A620 Shutter Button Replacement, Front Panel: stap 6, afbeelding 2 van 2
    • Gently pull the front panel to separate it from the camera.
    • The battery terminals are easy to access from this step.
  7. Canon PowerShot A620 Shutter Button Replacement, Terminal Cover: stap 7, afbeelding 1 van 2 Canon PowerShot A620 Shutter Button Replacement, Terminal Cover: stap 7, afbeelding 2 van 2
    • Gently pull the terminal cover to separate it from the camera.
  8. Canon PowerShot A620 Shutter Button Replacement, Memory Card Cover: stap 8, afbeelding 1 van 2 Canon PowerShot A620 Shutter Button Replacement, Memory Card Cover: stap 8, afbeelding 2 van 2
    • Slide the memory card cover down.
    • Unscrew the Phillips #00 1.6x3mm screw beneath the memory card cover.
  9. Canon PowerShot A620 Shutter Button Replacement, Back Panel: stap 9, afbeelding 1 van 2 Canon PowerShot A620 Shutter Button Replacement, Back Panel: stap 9, afbeelding 2 van 2
    • Gently pull the back panel to separate it from the camera.
  10. Canon PowerShot A620 Shutter Button Replacement, Metal Plate Screws: stap 10, afbeelding 1 van 2 Canon PowerShot A620 Shutter Button Replacement, Metal Plate Screws: stap 10, afbeelding 2 van 2
    • Unscrew the Phillips #00 1.6x3mm screw located on the top panel.
  11. Canon PowerShot A620 Shutter Button Replacement, Metal Plate: stap 11, afbeelding 1 van 1
    • Gently lift the metal plate and move it to the side.
  12. Canon PowerShot A620 Shutter Button Replacement, Trigger Button Screws: stap 12, afbeelding 1 van 2 Canon PowerShot A620 Shutter Button Replacement, Trigger Button Screws: stap 12, afbeelding 2 van 2
    • Unscrew the two Phillips #00 1.6x3mm screws that hold in the trigger button.
  13. Canon PowerShot A620 Shutter Button Replacement, Trigger Button: stap 13, afbeelding 1 van 1
    • The trigger button will fall off once the screws have been removed.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Jaime Abraham
350 Reputatie
3 handleidingen geschreven
CSU Fullerton, Team 1-1, Bruce Fall 2014 Lid van CSU Fullerton, Team 1-1, Bruce Fall 2014
CSUF-BRUCE-F14S1G1
3 Leden
6 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 12
Afgelopen 30 dagen: 32
Altijd: 1,690
