Ga door naar hoofdinhoud
Canon PowerShot A620 Camera Housing Replacement
Wat je nodig hebt
  1. Canon PowerShot A620 Camera Housing Replacement, Open Battery Door: stap 1, afbeelding 1 van 3 Canon PowerShot A620 Camera Housing Replacement, Open Battery Door: stap 1, afbeelding 2 van 3 Canon PowerShot A620 Camera Housing Replacement, Open Battery Door: stap 1, afbeelding 3 van 3
    • Slide the tab on the battery door while pushing the battery door away from you. The battery door should pop open.
  2. Canon PowerShot A620 Camera Housing Replacement, Insert Batteries: stap 2, afbeelding 1 van 2 Canon PowerShot A620 Camera Housing Replacement, Insert Batteries: stap 2, afbeelding 2 van 2
    • Insert AA batteries according to the diagram printed on the camera.
    • Close the battery door.
  3. Canon PowerShot A620 Camera Housing Replacement, Side Panel: stap 3, afbeelding 1 van 3 Canon PowerShot A620 Camera Housing Replacement, Side Panel: stap 3, afbeelding 2 van 3 Canon PowerShot A620 Camera Housing Replacement, Side Panel: stap 3, afbeelding 3 van 3
    • Unscrew the three Phillips #00 1.6x3mm screws on the side.
    • Lift loose panel from the case.
    • Unscrew the two Phillips #00 1.6x3mm screws that were previously hidden beneath the panel.
  4. Canon PowerShot A620 Camera Housing Replacement, Bottom Panel: stap 4, afbeelding 1 van 1
    • Unscrew the two Phillips #00 1.6x3mm screws on the bottom panel.
  5. Canon PowerShot A620 Camera Housing Replacement, Battery Compartment: stap 5, afbeelding 1 van 1
    • Open the battery door.
    • Unscrew the four Phillips #00 1.6x3mm screws in the battery compartment.
  6. Canon PowerShot A620 Camera Housing Replacement, Terminal Cover: stap 6, afbeelding 1 van 2 Canon PowerShot A620 Camera Housing Replacement, Terminal Cover: stap 6, afbeelding 2 van 2
    • Lift the terminal cover on the side of the camera.
    • Unscrew the three Phillips #00 1.6x3mm screws beneath the terminal cover.
  7. Canon PowerShot A620 Camera Housing Replacement, Top Panel: stap 7, afbeelding 1 van 1
    • Gently pull the top panel to separate it from the case.
    • Although the top panel will now be free from the rest of the case, it will still be attached to the camera by a ribbon cable.
  8. Canon PowerShot A620 Camera Housing Replacement, Front Panel: stap 8, afbeelding 1 van 2 Canon PowerShot A620 Camera Housing Replacement, Front Panel: stap 8, afbeelding 2 van 2
    • Gently pull the front panel to separate it from the camera.
    • The battery terminals are easy to access from this step.
  9. Canon PowerShot A620 Camera Housing Replacement, Terminal Cover: stap 9, afbeelding 1 van 2 Canon PowerShot A620 Camera Housing Replacement, Terminal Cover: stap 9, afbeelding 2 van 2
    • Gently pull the terminal cover to separate it from the camera.
  10. Canon PowerShot A620 Camera Housing Replacement, Memory Card Cover: stap 10, afbeelding 1 van 2 Canon PowerShot A620 Camera Housing Replacement, Memory Card Cover: stap 10, afbeelding 2 van 2
    • Slide the memory card cover down.
    • Unscrew the Phillips #00 1.6x3mm screw beneath the memory card cover.
  11. Canon PowerShot A620 Camera Housing Replacement, Back Panel: stap 11, afbeelding 1 van 2 Canon PowerShot A620 Camera Housing Replacement, Back Panel: stap 11, afbeelding 2 van 2
    • Gently pull the back panel to separate it from the camera.
Conclusie
Jaime Abraham
350 Reputatie
3 handleidingen geschreven
CSU Fullerton, Team 1-1, Bruce Fall 2014 Lid van CSU Fullerton, Team 1-1, Bruce Fall 2014
CSUF-BRUCE-F14S1G1
3 Leden
6 handleidingen geschreven
Één opmerking
Ottima spiegazione: é tutto facile quando la spiegazione é semplice ed univoca. Ma redigere istruzioni semplici é un'arte che non tutti possiedono.
Paolo Ravera - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 18
Altijd: 1,565
