Ga door naar hoofdinhoud
Canon PowerShot A590 IS LCD Screen Replacement
Wat je nodig hebt
  1. Canon PowerShot A590 IS LCD Screen Replacement, Batteries: stap 1, afbeelding 1 van 2 Canon PowerShot A590 IS LCD Screen Replacement, Batteries: stap 1, afbeelding 2 van 2
    • The battery hatch is on the bottom of the camera.
    • CAUTION: Locate the switch to open the hatch and push gently toward the front of the camera. Too much force can break the hatch.
    • While the switch is pushed forward, pull the cover away from the camera.
  2. Canon PowerShot A590 IS LCD Screen Replacement: stap 2, afbeelding 1 van 1
    • This camera requires AA batteries.
    • To remove batteries, simply allow them to fall out of the camera.
    • Use a fingernail to lift the clock battery out of the camera.
  3. Canon PowerShot A590 IS LCD Screen Replacement: stap 3, afbeelding 1 van 1
    • When replacing the AA batteries, verify they are oriented correctly by following the (+) and (-) signs on the camera.
  4. Canon PowerShot A590 IS LCD Screen Replacement, Back Cover: stap 4, afbeelding 1 van 1
    • Remove the screw located under the rubber flap on the left side of the camera using a Phillips #00 screwdriver.
  5. Canon PowerShot A590 IS LCD Screen Replacement: stap 5, afbeelding 1 van 1
    • Remove the two screws located on the other side of the camera using a Phillips #00 screwdriver.
  6. Canon PowerShot A590 IS LCD Screen Replacement: stap 6, afbeelding 1 van 1
    • Remove the three screws located at the bottom of the camera using a Phillips #00 screwdriver.
  7. Canon PowerShot A590 IS LCD Screen Replacement: stap 7, afbeelding 1 van 1
    • Open the battery cover.
    • Using the iFixit opening tool, push up gently around all edges of the camera.
  8. Canon PowerShot A590 IS LCD Screen Replacement, LCD Screen: stap 8, afbeelding 1 van 1
    • Remove the four screws near the corners of the LCD using a Phillips #00 screwdriver.
  9. Canon PowerShot A590 IS LCD Screen Replacement: stap 9, afbeelding 1 van 1
    • CAUTION: The LCD is connected to the motherboard with different wires and a ribbon. Using too much force may disconnect these parts.
    • Gently lift the screen from the motherboard.
    • Keep the LCD pulled back in one hand.
  10. Canon PowerShot A590 IS LCD Screen Replacement: stap 10, afbeelding 1 van 1
    • Use an iFixit opening tool to pull the black retaining clip up and disconnect the ribbon.
  11. Canon PowerShot A590 IS LCD Screen Replacement: stap 11, afbeelding 1 van 2 Canon PowerShot A590 IS LCD Screen Replacement: stap 11, afbeelding 2 van 2
    • Desolder the wires from the back of the LCD located in the bottom left corner.
    • Remove the solder from the wires.
    • Separate the LCD from the rest of the camera.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Zach
281 Reputatie
6 handleidingen geschreven
Cal Poly, Team 9-19, Regan Fall 2010 Lid van Cal Poly, Team 9-19, Regan Fall 2010
CPSU-REGAN-F10S9G19
4 Leden
14 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 8
Altijd: 9,659
