Deze versie kan foutieve bewerkingen bevatten. Schakel over naar de recentste gecontroleerde momentopname.
Wat je nodig hebt
Deze stap is niet vertaald. Help het te vertalen
While the switch is pushed forward, pull the cover away from the camera.
To remove batteries, simply allow them to fall out of the camera.
Use a fingernail to lift the clock battery out of the camera.
Remove the screw located under the rubber flap on the left side of the camera using a Phillips #00 screwdriver.
Remove the two screws located on the other side of the camera using a Phillips #00 screwdriver.
Remove the three screws located at the bottom of the camera using a Phillips #00 screwdriver.
Open the battery cover.
Using the iFixit opening tool, push up gently around all edges of the camera.
Press and hold down the button shown in the blue circle.
While pressing the button, rotate the lens cover in a counter-clockwise direction to remove it.
Remove the one (1) screw from the top of the camera, on the left side of the flash (looking from the front) using a Phillips #00 screwdriver.
Lift the black plastic covering off the circuit board.
Remove the green circuit board from the top. Looking from the front of the camera, first lift the left side up above the black peg. The board should then slide out to the left.
The flash logic board can now be removed from the camera and replaced.
3 andere personen hebben deze handleiding voltooid.
2 opmerkingen
If it is the flash element that needs to be replace, I presume I will see it when I’m there.
Is this correct ?
effitech_structure@yahoo.com
