Ga door naar hoofdinhoud
Canon PowerShot A590 IS Flash Assembly Replacement
Wat je nodig hebt
  1. Canon PowerShot A590 IS Flash Assembly Replacement, Batteries: stap 1, afbeelding 1 van 2 Canon PowerShot A590 IS Flash Assembly Replacement, Batteries: stap 1, afbeelding 2 van 2
    • The battery hatch is on the bottom of the camera.
    • CAUTION: Locate the switch to open the hatch and push gently toward the front of the camera. Too much force can break the hatch.
    • While the switch is pushed forward, pull the cover away from the camera.
    Can the hatch be replaced. The piece that holds the hatch is broken.
    alisonbforman46 - Antwoord
    I had this issue for some time and never realized that lithium battery was so easily accessible. Fixed my problem.
    Spud Head - Antwoord
  2. Canon PowerShot A590 IS Flash Assembly Replacement: stap 2, afbeelding 1 van 1
    • This camera requires AA batteries.
    • To remove batteries, simply allow them to fall out of the camera.
    • Use a fingernail to lift the clock battery out of the camera.
  3. Canon PowerShot A590 IS Flash Assembly Replacement: stap 3, afbeelding 1 van 1
    • When replacing the AA batteries, verify they are oriented correctly by following the (+) and (-) signs on the camera.
  4. Canon PowerShot A590 IS Flash Assembly Replacement, Back Cover: stap 4, afbeelding 1 van 1
    • Remove the screw located under the rubber flap on the left side of the camera using a Phillips #00 screwdriver.
  5. Canon PowerShot A590 IS Flash Assembly Replacement: stap 5, afbeelding 1 van 1
    • Remove the two screws located on the other side of the camera using a Phillips #00 screwdriver.
  6. Canon PowerShot A590 IS Flash Assembly Replacement: stap 6, afbeelding 1 van 1
    • Remove the three screws located at the bottom of the camera using a Phillips #00 screwdriver.
  7. Canon PowerShot A590 IS Flash Assembly Replacement: stap 7, afbeelding 1 van 1
    • Open the battery cover.
    • Using the iFixit opening tool, push up gently around all edges of the camera.
    Ik kan de achterkant er niet afkrijgen.
    De onderzijde gaat wel wat open, maar wat ik ook probeer de bovenzijde blijft op de een of andere manier haken en geeft geen krimp.
    Hopelijk hooft iemand hier iets op verzonnen om hem wel open te kunnen krijgen.
    mvrgr WH
    W.H. - Antwoord
  8. Canon PowerShot A590 IS Flash Assembly Replacement, Remove Lens Cover: stap 8, afbeelding 1 van 1
    • Press and hold down the button shown in the blue circle.
    • While pressing the button, rotate the lens cover in a counter-clockwise direction to remove it.
  9. Canon PowerShot A590 IS Flash Assembly Replacement, Remove Front Cover: stap 9, afbeelding 1 van 2 Canon PowerShot A590 IS Flash Assembly Replacement, Remove Front Cover: stap 9, afbeelding 2 van 2
    • Remove the front cover of the camera.
    • This may require a bit of force.
  10. Canon PowerShot A590 IS Flash Assembly Replacement, Remove Plastic Covering: stap 10, afbeelding 1 van 1
    • Remove the one (1) screw from the top of the camera, on the left side of the flash (looking from the front) using a Phillips #00 screwdriver.
    • Lift the black plastic covering off the circuit board.
  11. Canon PowerShot A590 IS Flash Assembly Replacement, Remove Green Circuit Board: stap 11, afbeelding 1 van 1
    • Remove the green circuit board from the top. Looking from the front of the camera, first lift the left side up above the black peg. The board should then slide out to the left.
    • The clear flash lens may fall out. Do not worry this will not affect the camera and can easily be placed back in its spot.
  12. Canon PowerShot A590 IS Flash Assembly Replacement, Unsolder Circuit Board Cables: stap 12, afbeelding 1 van 1
    • Unsolder the cables under the circuit board.
  13. Canon PowerShot A590 IS Flash Assembly Replacement: stap 13, afbeelding 1 van 1
    • The flash logic board can now be removed from the camera and replaced.
Conclusie
3 andere personen hebben deze handleiding voltooid.
Zach
281 Reputatie
6 handleidingen geschreven
Cal Poly, Team 9-19, Regan Fall 2010 Lid van Cal Poly, Team 9-19, Regan Fall 2010
CPSU-REGAN-F10S9G19
4 Leden
14 handleidingen geschreven
2 opmerkingen
Zach, can you show how to replace the Ring Release Button? The release button appears to be fixed to the front cover once it is removed. Can we purchase a replacement release button?
Jae Ennis - Antwoord
If it is the flash element that needs to be replace, I presume I will see it when I’m there.
Is this correct ?
effitech_structure@yahoo.com
Jean-François Rondeau - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 14
Altijd: 15,604
