Deze handleiding heeft recentere wijzigingen. Schakel over naar de nieuwste niet-geverifieerde versie.
Inleiding
You will remove screws from the bottom and sides of the camera in order to remove the cameras back cover.
Wat je nodig hebt
Remove the screw located under the rubber flap on the left side of the camera using a magnetic screwdriver.
Remove the two screws located on the other side of the camera using a magnetic screwdriver
Remove the three screws located at the bottom of the camera using a magnetic screwdriver.
Open the battery cover.
Using the iPod tool, push up gently around all edges of the camera.
7 andere personen hebben deze handleiding voltooid.
Één opmerking
i just wanted to by flap to replace over batteries it slides on and off reedalice270@gm.com
