Deze versie kan foutieve bewerkingen bevatten. Schakel over naar de recentste gecontroleerde momentopname.
Wat je nodig hebt
Deze stap is niet vertaald. Help het te vertalen
Unscrew a total of 6 4.45 mm phillips head screws using a #00 phillips head screwdriver.
There are 2 screws on the left side (when looking at the front of the camera).
There are 3 screws on the bottom
There is 1 screw on the right side
Turn to the bottom of the camera.
Open the memory card cover by sliding the "CARD/BATT." button up, and then pulling the cover to the left.
This is what the SD card/battery compartment looks like when opened.
Remove one 4.45mm phillips head screw from the SD card/battery compartment using a #00 phillips head screwdriver.
Gently remove the front cover away from the camera body.
The camera should look like this once the front cover is removed.
Start from the battery compartment and remove the back cover.
Remove the connecting ribbon from the body of the camera using a pair of tweezers.
Once the ribbon connecting the back cover is removed, the back of the camera body should look like this.
Remove two 4.35mm phillips head screws from around the LCD screen using a #00 phillips head screwdriver.
Loosen the black ribbon clamp using an iPod opening tool
Release the LCD screen by removing the ribbon from the body of the camera.
Unscrew 2 3.35mm phillips head screws from the face of the green circuit board using a #00 phillips head screwdriver.
Release the black ribbon clamp using an iPod opening tool to lift it.
Remove the ribbon connecting the circuit board from the body of the camera using tweezers.
The SD card reader is attached to the back of the circuit board. The circuit board and SD card combination should be replaced.
Één andere persoon heeft deze handleiding voltooid.
