Ga door naar hoofdinhoud
Canon PowerShot A540 Flash Motherboard Replacement
Wat je nodig hebt
  1. Canon PowerShot A540 Flash Motherboard Replacement, Back Cover: stap 1, afbeelding 1 van 2 Canon PowerShot A540 Flash Motherboard Replacement, Back Cover: stap 1, afbeelding 2 van 2
    • Turn off the camera.
    • Turn the camera upside-down and press the tab to release the battery cover. Remove the batteries.
  2. Canon PowerShot A540 Flash Motherboard Replacement: stap 2, afbeelding 1 van 1
    • Turn the camera upside down to view the "Card/Batt. Open" Cover.
    • Use a Phillips head #000 screwdriver to remove the three (3) 4.0 mm screws.
  3. Canon PowerShot A540 Flash Motherboard Replacement: stap 3, afbeelding 1 van 1
    • Open "Card/Batt. Open" Cover.
    • Remove the one (1) 5.0 mm screw with the Phillips head #000 screwdriver.
  4. Canon PowerShot A540 Flash Motherboard Replacement: stap 4, afbeelding 1 van 1
    • Turn the camera to the right side of the LCD screen.
    • Remove the three (3) 4.0 mm screws with the Phillips head #000 screwdriver.
  5. Canon PowerShot A540 Flash Motherboard Replacement: stap 5, afbeelding 1 van 3 Canon PowerShot A540 Flash Motherboard Replacement: stap 5, afbeelding 2 van 3 Canon PowerShot A540 Flash Motherboard Replacement: stap 5, afbeelding 3 van 3
    • Gently remove the back cover.
    • Start at the bottom at the corner of the "Card/Batt. Open" Cover.
    • Then move onto the other edges and the top.
    • It may be tight at the top!
  6. Canon PowerShot A540 Flash Motherboard Replacement, Front Cover: stap 6, afbeelding 1 van 2 Canon PowerShot A540 Flash Motherboard Replacement, Front Cover: stap 6, afbeelding 2 van 2
    • Turn the camera to view the front.
    • Remove the lens guard.
    • Press the lens guard's button as you turn the guard counterclockwise.
  7. Canon PowerShot A540 Flash Motherboard Replacement: stap 7, afbeelding 1 van 1
    • Turn the camera to the side left of the LCD screen.
    • Remove the one (1) 4.0 mm screw with the Phillips head #000 screwdriver.
  8. Canon PowerShot A540 Flash Motherboard Replacement: stap 8, afbeelding 1 van 1
    • Remove the front cover gently.
    • When removing the front cover, a thin, black rubber washer may fall off the lens. If it does, make sure to put it back on the lens before reassembly.
  9. Canon PowerShot A540 Flash Motherboard Replacement, Flash Motherboard: stap 9, afbeelding 1 van 1
    • Turn camera so that you see the top side with the settings wheel.
    • Use a Phillips head #000 screwdriver to remove the one (1) 5.0 mm screw at the top as shown.
  10. Canon PowerShot A540 Flash Motherboard Replacement: stap 10, afbeelding 1 van 2 Canon PowerShot A540 Flash Motherboard Replacement: stap 10, afbeelding 2 van 2
    • Remove plastic cover so that you can see the exposed motherboard.
  11. Canon PowerShot A540 Flash Motherboard Replacement: stap 11, afbeelding 1 van 2 Canon PowerShot A540 Flash Motherboard Replacement: stap 11, afbeelding 2 van 2
    • Gently pull the ribbon out.
  12. Canon PowerShot A540 Flash Motherboard Replacement: stap 12, afbeelding 1 van 1
    • Using a soldering iron and a desoldering wick, carefully disconnect all the wires from where they come into contact with the flash motherboard.
    • When all the wires are disconnected, you are ready to replace the flash motherboard.
    • If you have no experience with soldering, do not attempt to replace the flash motherboard. Seek help from someone who has experience with this equipment.
Conclusie
Jared
113 Reputatie
1 Handleiding geschreven
Baylor, Team 7-12, Williams Spring 2015 Lid van Baylor, Team 7-12, Williams Spring 2015
BU-WILLIAMS-S15S7G12
3 Leden
20 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 26
Altijd: 843
