Ga door naar hoofdinhoud
Canon PowerShot A460 Motherboard Replacement
Wat je nodig hebt
  1. Canon PowerShot A460 Motherboard Replacement, Battery: stap 1, afbeelding 1 van 1
    • Slide the switch on the battery cover labeled "CARD/BATT. OPEN." to the right.
    • While still holding the switch, pull the cover down, allowing it to release and open.
  2. Canon PowerShot A460 Motherboard Replacement: stap 2, afbeelding 1 van 1
    • Tilt the camera slightly to allow the batteries to fall out.
  3. Canon PowerShot A460 Motherboard Replacement: stap 3, afbeelding 1 van 1
    • Press on and release the memory card to eject it.
  4. Canon PowerShot A460 Motherboard Replacement, Front Casing: stap 4, afbeelding 1 van 1
    • Unscrew the 5mm Phillips #00 screw from the bottom of the camera.
    • Make sure to keep the different size screws organized to make reassembling the camera simpler.
  5. Canon PowerShot A460 Motherboard Replacement: stap 5, afbeelding 1 van 1
    • Unscrew the three 2mm Phillips #00 screws that are located on the bottom of the camera.
  6. Canon PowerShot A460 Motherboard Replacement: stap 6, afbeelding 1 van 1
    • Remove the 4mm Phillips #00 screw that is located on the left side of the camera, if the display screen is facing you.
  7. Canon PowerShot A460 Motherboard Replacement: stap 7, afbeelding 1 van 1
    • Take out the 4mm Phillips #00 screw under the rubber flap on the right end of the camera.
  8. Canon PowerShot A460 Motherboard Replacement: stap 8, afbeelding 1 van 2 Canon PowerShot A460 Motherboard Replacement: stap 8, afbeelding 2 van 2
    • Remove the second battery cover on the bottom of camera.
    • Take the silver battery out of the camera.
  9. Canon PowerShot A460 Motherboard Replacement: stap 9, afbeelding 1 van 3 Canon PowerShot A460 Motherboard Replacement: stap 9, afbeelding 2 van 3 Canon PowerShot A460 Motherboard Replacement: stap 9, afbeelding 3 van 3
    • Remove the 4mm Phillips #00 screw on the inside of the flap that hides the battery and memory card slots.
    • Remove the light grey, plastic piece.
    • Remove the plastic portion of the battery flap cover. The metal piece will remain attached.
  10. Canon PowerShot A460 Motherboard Replacement: stap 10, afbeelding 1 van 3 Canon PowerShot A460 Motherboard Replacement: stap 10, afbeelding 2 van 3 Canon PowerShot A460 Motherboard Replacement: stap 10, afbeelding 3 van 3
    • Slightly pull on each side of the camera. It should loosen up and come apart.
    • If it does not pull apart right away, use a little more force.
    • Do not give up!
  11. Canon PowerShot A460 Motherboard Replacement, Back Casing: stap 11, afbeelding 1 van 1
    • Remove the back case of the camera by pulling from the top.
    • Be careful when pulling off the case. There is a delicate gold ribbon connecting the bottom of the camera to the back case.
  12. Canon PowerShot A460 Motherboard Replacement, LCD Screen: stap 12, afbeelding 1 van 1
    • Remove the 4mm Phillips #00 screw from above the ribbon.
  13. Canon PowerShot A460 Motherboard Replacement: stap 13, afbeelding 1 van 1
    • Gently peel off the blue tape on the top of the LCD screen.
  14. Canon PowerShot A460 Motherboard Replacement: stap 14, afbeelding 1 van 1
    • Remove the 4mm Phillips #00 screw previously concealed by the blue tape.
  15. Canon PowerShot A460 Motherboard Replacement: stap 15, afbeelding 1 van 1
    • Gently lift the LCD screen off of the front casing by pulling up a tab on the side of the camera.
  16. Canon PowerShot A460 Motherboard Replacement: stap 16, afbeelding 1 van 1
    • Using a spudger, lift the grey tabs to allow the ribbon to slide out.
  17. Canon PowerShot A460 Motherboard Replacement: stap 17, afbeelding 1 van 1
    • Since the tabs have been lifted, the ribbon should now slide out out easily.
    • Be careful not to distort the ribbon in any way.
  18. Canon PowerShot A460 Motherboard Replacement, Motherboard: stap 18, afbeelding 1 van 1
    • Remove the 5mm Phillips #00 screw located above the small black piece on the right side of the mother board.
  19. Canon PowerShot A460 Motherboard Replacement: stap 19, afbeelding 1 van 2 Canon PowerShot A460 Motherboard Replacement: stap 19, afbeelding 2 van 2
    • Remove the 4mm Phillips #00 screw at the bottom of the black piece.
    • Detach the black piece that the screws previously held in place.
  20. Canon PowerShot A460 Motherboard Replacement: stap 20, afbeelding 1 van 1
    • Remove the 5mm Phillips #00 screw in the middle of the motherboard.
  21. Canon PowerShot A460 Motherboard Replacement: stap 21, afbeelding 1 van 1
    • Remove the 5mm Phillips #00 screw that holds the metal piece to the bottom of the camera .
  22. Canon PowerShot A460 Motherboard Replacement: stap 22, afbeelding 1 van 1
    • Remove the 5mm Phillips #00 screw that is located on the top of camera.
  23. Canon PowerShot A460 Motherboard Replacement: stap 23, afbeelding 1 van 1
    • Remove the 2mm Phillips #00 screw that is located on the far left of the motherboard.
    • Be careful not to damage the multiple adjacent orange ribbons.
  24. Canon PowerShot A460 Motherboard Replacement: stap 24, afbeelding 1 van 1
    • Remove the 5mm Phillips #00 screw near the bottom left of the motherboard.
  25. Canon PowerShot A460 Motherboard Replacement: stap 25, afbeelding 1 van 2 Canon PowerShot A460 Motherboard Replacement: stap 25, afbeelding 2 van 2
    • Using a spudger, unlock the locking mechanism that holds the lower orange ribbon in place.
    • Once unlocked, slide out the ribbon.
  26. Canon PowerShot A460 Motherboard Replacement: stap 26, afbeelding 1 van 1
    • Using a spudger, unlock the locking mechanism that holds the upper orange ribbon in place.
  27. Canon PowerShot A460 Motherboard Replacement: stap 27, afbeelding 1 van 1
    • All that is required is to unsolder the few remaining wires. Then, the motherboard will be ready to be replaced!
Conclusie
Tanner Coleman
40 Reputatie
2 handleidingen geschreven
Cal Poly, Team 19-42, Regan Winter 2013 Lid van Cal Poly, Team 19-42, Regan Winter 2013
CPSU-REGAN-W13S19G42
4 Leden
12 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 9
Altijd: 1,574
