Deze versie kan foutieve bewerkingen bevatten. Schakel over naar de recentste gecontroleerde momentopname.
Wat je nodig hebt
Deze stap is niet vertaald. Help het te vertalen
Slide the switch on the battery cover labeled "CARD/BATT. OPEN." to the right.
While still holding the switch, pull the cover down, allowing it to release and open.
Tilt the camera slightly to allow the batteries to fall out.
Unscrew the 5mm Phillips #00 screw from the bottom of the camera.
Unscrew the three 2mm Phillips #00 screws that are located on the bottom of the camera.
Remove the 4mm Phillips #00 screw that is located on the left side of the camera, if the display screen is facing you.
Take out the 4mm Phillips #00 screw under the rubber flap on the right end of the camera.
Remove the second battery cover on the bottom of camera.
Take the silver battery out of the camera.
Remove the 4mm Phillips #00 screw on the inside of the flap that hides the battery and memory card slots.
Remove the light grey, plastic piece.
Remove the plastic portion of the battery flap cover. The metal piece will remain attached.
Slightly pull on each side of the camera. It should loosen up and come apart.
If it does not pull apart right away, use a little more force.
Do not give up!
Remove the back case of the camera by pulling from the top.
Remove the 4mm Phillips #00 screw from above the ribbon.
Gently peel off the blue tape on the top of the LCD screen.
Remove the 4mm Phillips #00 screw previously concealed by the blue tape.
Gently lift the LCD screen off of the front casing by pulling up a tab on the side of the camera.
Using a spudger, lift the grey tabs to allow the ribbon to slide out.
Since the tabs have been lifted, the ribbon should now slide out out easily.
3 andere personen hebben deze handleiding voltooid.
2 opmerkingen
Explained in detail, very clear, easy to understand. I just unpacked it for the first time. Still able to do as told. Thank you.
