Ga door naar hoofdinhoud
Canon PowerShot A460 Front Casing Replacement
Wat je nodig hebt
  1. Canon PowerShot A460 Front Casing Replacement, Battery: stap 1, afbeelding 1 van 1
    • Slide the switch on the battery cover labeled "CARD/BATT. OPEN." to the right.
    • While still holding the switch, pull the cover down, allowing it to release and open.
  2. Canon PowerShot A460 Front Casing Replacement: stap 2, afbeelding 1 van 1
    • Tilt the camera slightly to allow the batteries to fall out.
  3. Canon PowerShot A460 Front Casing Replacement: stap 3, afbeelding 1 van 1
    • Press on and release the memory card to eject it.
  4. Canon PowerShot A460 Front Casing Replacement, Front Casing: stap 4, afbeelding 1 van 1
    • Unscrew the 5mm Phillips #00 screw from the bottom of the camera.
    • Make sure to keep the different size screws organized to make reassembling the camera simpler.
  5. Canon PowerShot A460 Front Casing Replacement: stap 5, afbeelding 1 van 1
    • Unscrew the three 2mm Phillips #00 screws that are located on the bottom of the camera.
  6. Canon PowerShot A460 Front Casing Replacement: stap 6, afbeelding 1 van 1
    • Remove the 4mm Phillips #00 screw that is located on the left side of the camera, if the display screen is facing you.
  7. Canon PowerShot A460 Front Casing Replacement: stap 7, afbeelding 1 van 1
    • Take out the 4mm Phillips #00 screw under the rubber flap on the right end of the camera.
  8. Canon PowerShot A460 Front Casing Replacement: stap 8, afbeelding 1 van 2 Canon PowerShot A460 Front Casing Replacement: stap 8, afbeelding 2 van 2
    • Remove the second battery cover on the bottom of camera.
    • Take the silver battery out of the camera.
  9. Canon PowerShot A460 Front Casing Replacement: stap 9, afbeelding 1 van 3 Canon PowerShot A460 Front Casing Replacement: stap 9, afbeelding 2 van 3 Canon PowerShot A460 Front Casing Replacement: stap 9, afbeelding 3 van 3
    • Remove the 4mm Phillips #00 screw on the inside of the flap that hides the battery and memory card slots.
    • Remove the light grey, plastic piece.
    • Remove the plastic portion of the battery flap cover. The metal piece will remain attached.
  10. Canon PowerShot A460 Front Casing Replacement: stap 10, afbeelding 1 van 3 Canon PowerShot A460 Front Casing Replacement: stap 10, afbeelding 2 van 3 Canon PowerShot A460 Front Casing Replacement: stap 10, afbeelding 3 van 3
    • Slightly pull on each side of the camera. It should loosen up and come apart.
    • If it does not pull apart right away, use a little more force.
    • Do not give up!
Conclusie
Alex
85 Reputatie
2 handleidingen geschreven
Cal Poly, Team 19-42, Regan Winter 2013 Lid van Cal Poly, Team 19-42, Regan Winter 2013
CPSU-REGAN-W13S19G42
4 Leden
12 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 5
Altijd: 785
