Ga door naar hoofdinhoud
Canon PowerShot A4000 IS SD Card Replacement
Wat je nodig hebt
  1. Canon PowerShot A4000 IS SD Card Replacement, Reinserting Memory Card: stap 1, afbeelding 1 van 1
    • The inside of your Canon PowerShot A4000 camera should have a picture showing how to reinsert your memory card.
    • Line the memory card up like it is shown in the camera and using your thumb, press down on the card until you hear a click. Your memory card is now back in place and ready for use.
  2. Canon PowerShot A4000 IS SD Card Replacement, Memory Card Removal: stap 2, afbeelding 1 van 2 Canon PowerShot A4000 IS SD Card Replacement, Memory Card Removal: stap 2, afbeelding 2 van 2
    • To open the battery compartment where the memory card is stored, refer to the Battery Replacement Guide.
    • The memory card is stored behind the battery on the side opposite of the lens as outlined by the red rectangle in the picture.
    • To remove the memory card, use your thumb to press down on the exposed part of the card.
    • The card will dip down further into the compartment and then you will hear a click as the card is released.
Conclusie
Ansley Gardner
761 Reputatie
7 handleidingen geschreven
Clemson, Team 1-3, Benson Fall 2014 Lid van Clemson, Team 1-3, Benson Fall 2014
CLEM-BENSON-F14S1G3
3 Leden
17 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 21
Altijd: 908
