Ga door naar hoofdinhoud
Canon PowerShot A4000 IS Flash Replacement
Wat je nodig hebt
  1. Canon PowerShot A4000 IS Flash Replacement, Removing the Screws Anchoring the Front Cover: stap 1, afbeelding 1 van 3 Canon PowerShot A4000 IS Flash Replacement, Removing the Screws Anchoring the Front Cover: stap 1, afbeelding 2 van 3 Canon PowerShot A4000 IS Flash Replacement, Removing the Screws Anchoring the Front Cover: stap 1, afbeelding 3 van 3
    • Remove the battery and data card. Refer to the Battery Removal and Memory Card Removal guides.
    • Use a Philips head screwdriver (PH000) to remove the screws circled in the picture. Screw Sizes: 4 millimeters.
  2. Canon PowerShot A4000 IS Flash Replacement: stap 2, afbeelding 1 van 2 Canon PowerShot A4000 IS Flash Replacement: stap 2, afbeelding 2 van 2
    • Use the spudger tool to gently lever the front cover off.
  3. Canon PowerShot A4000 IS Flash Replacement, Removing the Flash: stap 3, afbeelding 1 van 3 Canon PowerShot A4000 IS Flash Replacement, Removing the Flash: stap 3, afbeelding 2 van 3 Canon PowerShot A4000 IS Flash Replacement, Removing the Flash: stap 3, afbeelding 3 van 3
    • The flash is not held very securely in the camera so be careful. Make sure someone is holding on to it so it does not fall out.
    • Your flash should come out very easily if you use your spudger to lever it out carefully.
    • Once the bulb piece of the flash is clear of the camera body, simply use your fingers to lift the flash clear of the camera.
Conclusie
Ansley Gardner
761 Reputatie
7 handleidingen geschreven
Clemson, Team 1-3, Benson Fall 2014 Lid van Clemson, Team 1-3, Benson Fall 2014
CLEM-BENSON-F14S1G3
3 Leden
17 handleidingen geschreven
Één opmerking
Hello! thank you for this flash replacement guide. I would like to know: can the flash be repaired or is it only replaceable? Thank you!
Jeiler AV - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 36
Altijd: 1,818
