Inleiding
This guide is important since it will allow you to access the internal components of the camera. It will also allow you to replace the plastic case if the case has been damaged or warped in any fashion.
Wat je nodig hebt
Place thumb on area right next to where it says open and slide to the right to open.
Remove the two 5.00 mm screws in the bottom of the casing with a Philips #000 screwdriver
Één andere persoon heeft deze handleiding voltooid.
