Inleiding
The following steps will help you replace the flash assembly for the Canon PowerShot A3400 model. You would want to do this if the camera's flash is no longer functioning and you have exhausted your troubleshooting to the point where the source of the issue lies with the flash assembly.
Wat je nodig hebt
Place thumb on area right next to where it says open and slide to the right to open.
Remove the two 5.00 mm screws in the bottom of the casing with a Philips #000 screwdriver
Één andere persoon heeft deze handleiding voltooid.
