Ga door naar hoofdinhoud
Canon PowerShot A2200 Back Cover Replacement
Wat je nodig hebt
  1. Canon PowerShot A2200 Back Cover Replacement, Back Cover: stap 1, afbeelding 1 van 1
    • First, remove the batteries and memory card.
    • Remove the 5.0 mm black screw with a Phillips #00 screwdriver.
    • Remove the 5.0 mm silver screw with a Phillips #00 screwdriver.
  2. Canon PowerShot A2200 Back Cover Replacement: stap 2, afbeelding 1 van 1
    • Remove the 5.0 mm black screw on the right with a Phillips #00 screwdriver.
  3. Canon PowerShot A2200 Back Cover Replacement: stap 3, afbeelding 1 van 1
    • Remove the 5.0 mm screw on the left with a Phillips #00 screwdriver.
  4. Canon PowerShot A2200 Back Cover Replacement: stap 4, afbeelding 1 van 3 Canon PowerShot A2200 Back Cover Replacement: stap 4, afbeelding 2 van 3 Canon PowerShot A2200 Back Cover Replacement: stap 4, afbeelding 3 van 3
    • Begin taking off the back cover with a plastic opening tool.
    • Begin by wedging the plastic opening tool behind the bottom left corner of the LCD screen as shown.
    • Slide the plastic opening tool to the right, along the mating edge, to pry off the back cover.
    • Continue taking off the back cover along the left side of the camera as seen in the third picture.
  5. Canon PowerShot A2200 Back Cover Replacement: stap 5, afbeelding 1 van 3 Canon PowerShot A2200 Back Cover Replacement: stap 5, afbeelding 2 van 3 Canon PowerShot A2200 Back Cover Replacement: stap 5, afbeelding 3 van 3
    • Use the plastic opening tool to separate the top section of the back cover from the frame.
    • Once there is enough separation between the back cover and the frame, remove the back cover for replacement.
Conclusie
Jessica Huebschman
140 Reputatie
1 Handleiding geschreven
Baylor, Team 4-5, Williams Spring 2015 Lid van Baylor, Team 4-5, Williams Spring 2015
BU-WILLIAMS-S15S4G5
4 Leden
11 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 16
Altijd: 928
