1. Start by removing the case in the previous guide. The battery door is held in place with a steel dowel but first undo the spring tension by lifting the spring out of it's retainer with a pair of tweezers or small screwdriver. The battery door is held in place with a steel dowel but first undo the spring tension by lifting the spring out of it's retainer with a pair of tweezers or small screwdriver.
    • Start by removing the case in the previous guide.
    • The battery door is held in place with a steel dowel but first undo the spring tension by lifting the spring out of it's retainer with a pair of tweezers or small screwdriver.
  2. Gratis verzending van alle bestellingen van meer dan US$ 100 of met een Pro Tech Toolkit!
    Doorblader onze winkel
  3. Once the spring is clear of the plastic, you can easily push the dowel through with a pin, the end of the tweezers, or a paperclip. Grab the dowel from the other end and pull it out. Grab the dowel from the other end and pull it out.
    • Once the spring is clear of the plastic, you can easily push the dowel through with a pin, the end of the tweezers, or a paperclip.
    • Grab the dowel from the other end and pull it out.
Conclusie
4 andere personen hebben deze handleiding voltooid.
Biff Wheeler
762 Reputatie
4 handleidingen geschreven
Één commentaar
Hi I have the camera of same model A1000.
Where can I get the battery cover, mine is broken?
Please share the details.
Chennakeshava Reddy Palla - Antwoord
Weergavestatistieken:
Afgelopen 24 Uren: 1
Afgelopen 7 Dagen: 6
Afgelopen 30 Dagen: 16
Altijd: 2,599
