Ga door naar hoofdinhoud
Wat je nodig hebt
Deze demontage is geen reparatiehandleiding. Om je Canon PIXMA iP4850 te repareren, gebruik onze reparatiehandleidingen.
  1. Canon PIXMA iP4850 Teardown, Canon PIXMA iP4850 Teardown: stap 1, afbeelding 1 van 1
    • this printer has the well known B200 error.
    • we will take the printer apart.
    • first step : remove all the loose parts.
    • remove the panel at the back.
  2. Canon PIXMA iP4850 Teardown: stap 2, afbeelding 1 van 3 Canon PIXMA iP4850 Teardown: stap 2, afbeelding 2 van 3 Canon PIXMA iP4850 Teardown: stap 2, afbeelding 3 van 3
    • no we will remove the printhead and the cardridges.
    • be carefull with the remaining inkt.
    • To remove the printhead you have to plug in the printer again and open up te front panel (like you have to remove the cardridges).
    • to remove the printhead you have to pull the levar up (grey) , be carefull its very rough to pull it up.
    • remove the printhead, if you only replace the printhead the guide stops here. be carefull for the pcb board, if you only clean the printhead do it carefully. clean it with destilled water, but do not touch the PCB.
  3. Canon PIXMA iP4850 Teardown: stap 3, afbeelding 1 van 3 Canon PIXMA iP4850 Teardown: stap 3, afbeelding 2 van 3 Canon PIXMA iP4850 Teardown: stap 3, afbeelding 3 van 3
    • remove the papertrunk at the botom, see picture 3
    • now remove the screws at the white clips.
  4. Canon PIXMA iP4850 Teardown: stap 4, afbeelding 1 van 3 Canon PIXMA iP4850 Teardown: stap 4, afbeelding 2 van 3 Canon PIXMA iP4850 Teardown: stap 4, afbeelding 3 van 3
    • now we will remove the power supply.
    • you'll find clips to loose the power suply . On the picture (number 1) you see how you do it. you'll here the clicks.
    • pull the power supply out of the printer, and you will see the white and blue wires. you will see this wires later in the printer again.
  5. Canon PIXMA iP4850 Teardown: stap 5, afbeelding 1 van 3 Canon PIXMA iP4850 Teardown: stap 5, afbeelding 2 van 3 Canon PIXMA iP4850 Teardown: stap 5, afbeelding 3 van 3
    • remove the side panels
    • you can remove this by clicking the panel of.
    • search for the arrows on the upper deck of the printer. see picture 1
    • than click the panel losse at the bottom of the printer.
    • again, and i think you know already, it's not so easy to take the printer apart. It's a lot of clicking the panels loose. and sometimes you will think the plastic will brake but it's quite flexible.
    • at the left side you'll find the paper drive roll. and at the right side the PCB boards
  6. Canon PIXMA iP4850 Teardown: stap 6, afbeelding 1 van 3 Canon PIXMA iP4850 Teardown: stap 6, afbeelding 2 van 3 Canon PIXMA iP4850 Teardown: stap 6, afbeelding 3 van 3
    • remove the upper panel by clicking two clips. at the backside.
    • normaly , if my guide is good enough, the printer looks like picture 3 now.
  7. Canon PIXMA iP4850 Teardown: stap 7, afbeelding 1 van 3 Canon PIXMA iP4850 Teardown: stap 7, afbeelding 2 van 3 Canon PIXMA iP4850 Teardown: stap 7, afbeelding 3 van 3
    • remove the printer paper roll
    • remove the red circled screws.
    • this step and the next is actualy 1 big step.
  8. Canon PIXMA iP4850 Teardown: stap 8, afbeelding 1 van 3 Canon PIXMA iP4850 Teardown: stap 8, afbeelding 2 van 3 Canon PIXMA iP4850 Teardown: stap 8, afbeelding 3 van 3
    • remove the 2 screws. one on a PCB board and the other in the white plastic.
    • remove the long PCB , remove the three thick screws
  9. Canon PIXMA iP4850 Teardown: stap 9, afbeelding 1 van 3 Canon PIXMA iP4850 Teardown: stap 9, afbeelding 2 van 3 Canon PIXMA iP4850 Teardown: stap 9, afbeelding 3 van 3
    • remove all the wires, some are attached to the PCB.
    • now you can remove the paper roll.
  10. Canon PIXMA iP4850 Teardown: stap 10, afbeelding 1 van 3 Canon PIXMA iP4850 Teardown: stap 10, afbeelding 2 van 3 Canon PIXMA iP4850 Teardown: stap 10, afbeelding 3 van 3
    • remove the other visible scerws at the back.
  11. Canon PIXMA iP4850 Teardown: stap 11, afbeelding 1 van 3 Canon PIXMA iP4850 Teardown: stap 11, afbeelding 2 van 3 Canon PIXMA iP4850 Teardown: stap 11, afbeelding 3 van 3
    • same as before, remove all other visible screws at the side.
  12. Canon PIXMA iP4850 Teardown: stap 12, afbeelding 1 van 2 Canon PIXMA iP4850 Teardown: stap 12, afbeelding 2 van 2
    • now remove the metal plate (long) , 4 screws in total. 1 screw is attached at an PCB board.
  13. Canon PIXMA iP4850 Teardown: stap 13, afbeelding 1 van 3 Canon PIXMA iP4850 Teardown: stap 13, afbeelding 2 van 3 Canon PIXMA iP4850 Teardown: stap 13, afbeelding 3 van 3
    • the pictures here are to remove the other metal plate, you'll see the colored wires running trough. remove the plastic and metal frame
  14. Canon PIXMA iP4850 Teardown: stap 14, afbeelding 1 van 3 Canon PIXMA iP4850 Teardown: stap 14, afbeelding 2 van 3 Canon PIXMA iP4850 Teardown: stap 14, afbeelding 3 van 3
    • in this step we will remove the panel and PCB of the power button.
    • remove the visible screws and pull the plastic frame off.
  15. Canon PIXMA iP4850 Teardown: stap 15, afbeelding 1 van 3 Canon PIXMA iP4850 Teardown: stap 15, afbeelding 2 van 3 Canon PIXMA iP4850 Teardown: stap 15, afbeelding 3 van 3
    • remove the main PCB board.
    • remind were al the wires run to. i made a plan of it so i could use it later in an other printer.
  16. Canon PIXMA iP4850 Teardown: stap 16, afbeelding 1 van 3 Canon PIXMA iP4850 Teardown: stap 16, afbeelding 2 van 3 Canon PIXMA iP4850 Teardown: stap 16, afbeelding 3 van 3
    • remove the metal plate and screw behind the PCB board
    • remove the plate and remove the hidden screws
  17. Canon PIXMA iP4850 Teardown: stap 17, afbeelding 1 van 2 Canon PIXMA iP4850 Teardown: stap 17, afbeelding 2 van 2
    • remove all other screws
  18. Canon PIXMA iP4850 Teardown: stap 18, afbeelding 1 van 3 Canon PIXMA iP4850 Teardown: stap 18, afbeelding 2 van 3 Canon PIXMA iP4850 Teardown: stap 18, afbeelding 3 van 3
    • remove the metal plate ( where the printhead cable runs trough)
  19. Canon PIXMA iP4850 Teardown: stap 19, afbeelding 1 van 2 Canon PIXMA iP4850 Teardown: stap 19, afbeelding 2 van 2
    • remove the last screws from the bottom plate
  20. Canon PIXMA iP4850 Teardown: stap 20, afbeelding 1 van 3 Canon PIXMA iP4850 Teardown: stap 20, afbeelding 2 van 3 Canon PIXMA iP4850 Teardown: stap 20, afbeelding 3 van 3
    • remove the white plastic plate like you see on the pictures
  21. Canon PIXMA iP4850 Teardown: stap 21, afbeelding 1 van 3 Canon PIXMA iP4850 Teardown: stap 21, afbeelding 2 van 3 Canon PIXMA iP4850 Teardown: stap 21, afbeelding 3 van 3
    • remove the plastic rotors.
  22. Canon PIXMA iP4850 Teardown: stap 22, afbeelding 1 van 3 Canon PIXMA iP4850 Teardown: stap 22, afbeelding 2 van 3 Canon PIXMA iP4850 Teardown: stap 22, afbeelding 3 van 3
    • gently remove the ink tubes.
    • there is still inkt left in the tubes so use cotton towels or tissues.
  23. Canon PIXMA iP4850 Teardown: stap 23, afbeelding 1 van 3 Canon PIXMA iP4850 Teardown: stap 23, afbeelding 2 van 3 Canon PIXMA iP4850 Teardown: stap 23, afbeelding 3 van 3
    • in the last pictures you will see all the parts like the motor PCB boards, power button print head holder ...
    • hope this guide helped you out.
Kevin D
7.532 Reputatie
21 handleidingen geschreven
4Gids Commentaar
Fixing back the printer but the connector wires are damaged in the ends any better way to get the connectors working again?
Paneer Selvam - Antwoord Deel
which connectors do you mean? soldering?
Kevin D - Antwoord Deel
unfortunately the Pixma MP printers and AIO are one of the most complicated to repair and undocumented in service guides printers in the world :(
Daniel Grafic - Antwoord Deel
Bonsoir,
Félicitations pour ce super tuto !
J'ai cherché sans succès sur le site son semblable pour une imprimante CANON IP 7250.
J'ai reçu un code B200 ; nettoyage tête d'impression et absorbeur d'encre.
J'avais rencontré ce problème il y a 2 ans et l'avais résolu en nettoyant la tête d'impression avec de l'eau distillée, mais cette fois c'est insuffisant. Il me faut passer à l'étape absorbeurs beaucoup plus lourde. Auriez-vous un tuto pour cette imprimante ou pourriez-vous m'indiquer le processus pour y accéder ?
NB : le démontage de la machine est fortement avancé.
Par avance, un grand merci, je ne voudrai pas rentrer dans le jeu de CANON consistant à forcer la vente au détriment d'une réparation.
Tous vos conseils seront bienvenus.
Bonne soirée. Dan
Dan GUR - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 6
Afgelopen 7 dagen: 37
Afgelopen 30 dagen: 119
Altijd: 18,413
