Ga door naar hoofdinhoud
Canon PIXMA iP3600 Printhead Replacement
  1. Canon PIXMA iP3600 Printhead Replacement, Ink Cartridges: stap 1, afbeelding 1 van 1
    • Press the power button to turn on the printer.
  2. Canon PIXMA iP3600 Printhead Replacement: stap 2, afbeelding 1 van 1
    • Pull down the front output tray cover.
  3. Canon PIXMA iP3600 Printhead Replacement: stap 3, afbeelding 1 van 1
    • Lift the printer lid.
  4. Canon PIXMA iP3600 Printhead Replacement: stap 4, afbeelding 1 van 1
    • Allow the belt, containing ink cartridges, to adjust and center so that the ink cartridges are visible.
  5. Canon PIXMA iP3600 Printhead Replacement: stap 5, afbeelding 1 van 2 Canon PIXMA iP3600 Printhead Replacement: stap 5, afbeelding 2 van 2
    • Push in the white clip to release the ink cartridge from the printhead.
    • Lift the ink cartridge from the printhead.
    • Repeat this process for the remaining ink cartridges.
    • You have successfully removed all ink cartridges.
  6. Canon PIXMA iP3600 Printhead Replacement, Printhead: stap 6, afbeelding 1 van 1
    • After removing all ink cartridges, lift the printhead lock lever.
  7. Canon PIXMA iP3600 Printhead Replacement: stap 7, afbeelding 1 van 1
    • Pull up and lift out the black piece that previously held the ink cartridges. This is the printhead.
    Comment réparer la tête d'impression
    Mohamed el amine Baali - Antwoord
  8. Canon PIXMA iP3600 Printhead Replacement: stap 8, afbeelding 1 van 1
    • You have successfully removed your printhead.
Conclusie
5 andere personen hebben deze handleiding voltooid.
Caitlyn
1.184 Reputatie
4 handleidingen geschreven
USF Tampa, Team 1-3, Leahy Fall 2014 Lid van USF Tampa, Team 1-3, Leahy Fall 2014
USFT-LEAHY-F14S1G3
3 Leden
8 handleidingen geschreven
Één opmerking
fairly helpful, especially the photo's. but I need advice on how to clean the printhead before trying to replace it,
a1halber - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 13
Afgelopen 30 dagen: 39
Altijd: 7,666
