Ga door naar hoofdinhoud
Canon PIXMA iP3600 AC Adapter Replacement
  1. Canon PIXMA iP3600 AC Adapter Replacement, AC Adapter: stap 1, afbeelding 1 van 2 Canon PIXMA iP3600 AC Adapter Replacement, AC Adapter: stap 1, afbeelding 2 van 2
    • It is very important to disconnect your printer from the outlet before attempting replacement. This ensures that there is no power reaching the AC adapter.
    • Remove power cord by disconnecting it from the AC Adapter.
  2. Canon PIXMA iP3600 AC Adapter Replacement: stap 2, afbeelding 1 van 2 Canon PIXMA iP3600 AC Adapter Replacement: stap 2, afbeelding 2 van 2
    • Pinch upper and lower prongs, moving them away from the AC adapter.
  3. Canon PIXMA iP3600 AC Adapter Replacement: stap 3, afbeelding 1 van 2 Canon PIXMA iP3600 AC Adapter Replacement: stap 3, afbeelding 2 van 2
    • The AC adapter will now be loose, and able to come away from the printer.
    • Grasp the AC adapter and pull it toward you to remove it.
  4. Canon PIXMA iP3600 AC Adapter Replacement: stap 4, afbeelding 1 van 1
    • Rotate the AC adapter toward you so that the blue cord, with white connector head, is facing you.
  5. Canon PIXMA iP3600 AC Adapter Replacement: stap 5, afbeelding 1 van 3 Canon PIXMA iP3600 AC Adapter Replacement: stap 5, afbeelding 2 van 3 Canon PIXMA iP3600 AC Adapter Replacement: stap 5, afbeelding 3 van 3
    • Grasp the white connector head that is attached to the end of the blue cord.
    • Disconnect the white connector head by gently pulling it away from the AC adapter.
    • You have successfully removed the AC adapter.
Conclusie
7 andere personen hebben deze handleiding voltooid.
Caitlyn
1.184 Reputatie
4 handleidingen geschreven
USF Tampa, Team 1-3, Leahy Fall 2014 Lid van USF Tampa, Team 1-3, Leahy Fall 2014
USFT-LEAHY-F14S1G3
3 Leden
8 handleidingen geschreven
3 opmerkingen
Does anybody know the pin-out for these power supplies?
James Rudee - Antwoord
WHERE CAN I BUY AC ADAPTER PIXMA GM 5220 PRINTER ? PLAESE !! my cell 678 899 1187, 770368 0409 w
vincent lieu - Antwoord
Well I’ve just taken the AC Adapter out - I’ll let you know if a the replacement works once I’ve purchased it - Which I am hesitant to buy in case that’s not the problem.
The printer is barely 2 years old and barely used, I shouldn’t be experiencing this problem of the printer not turning on.
Canon you need to get your act together if you would like to stay in business, I’m seeing a lot of comments on this problem over a range of different printer models - Mine is a Pixma iX6860.
rezidraft - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 21
Altijd: 4,858
