Ga door naar hoofdinhoud
Canon PIXMA TS3300 Ink Cartridge Replacement
Wat je nodig hebt
  1. Canon PIXMA TS3300 Ink Cartridge Replacement, Ink Cartridge: stap 1, afbeelding 1 van 2 Canon PIXMA TS3300 Ink Cartridge Replacement, Ink Cartridge: stap 1, afbeelding 2 van 2
    • Press the power button in the top left corner to turn on the printer.
    • The light next to the button will turn green if the printer is on.
  2. Canon PIXMA TS3300 Ink Cartridge Replacement: stap 2, afbeelding 1 van 2 Canon PIXMA TS3300 Ink Cartridge Replacement: stap 2, afbeelding 2 van 2
    • Lift the cartridge compartment located in the front of the printer to gain access on the inside of the printer.
    • Allow for the cartridge holder to move into view.
  3. Canon PIXMA TS3300 Ink Cartridge Replacement: stap 3, afbeelding 1 van 2 Canon PIXMA TS3300 Ink Cartridge Replacement: stap 3, afbeelding 2 van 2
    • The cartridge should be located in the center of the printer.
    • Push down on the cartridge and pull it out.
  4. Canon PIXMA TS3300 Ink Cartridge Replacement: stap 4, afbeelding 1 van 2 Canon PIXMA TS3300 Ink Cartridge Replacement: stap 4, afbeelding 2 van 2
    • Prepare the new cartridge by peeling off the cover.
  5. Canon PIXMA TS3300 Ink Cartridge Replacement: stap 5, afbeelding 1 van 3 Canon PIXMA TS3300 Ink Cartridge Replacement: stap 5, afbeelding 2 van 3 Canon PIXMA TS3300 Ink Cartridge Replacement: stap 5, afbeelding 3 van 3
    • Peel off the orange sticker on the left side of the cartridge.
  6. Canon PIXMA TS3300 Ink Cartridge Replacement: stap 6, afbeelding 1 van 2 Canon PIXMA TS3300 Ink Cartridge Replacement: stap 6, afbeelding 2 van 2
    • Insert the cartridge at an angle to the cartridge holder.
    • Push upward on the cartridge until a clicking sound is heard.
  7. Canon PIXMA TS3300 Ink Cartridge Replacement: stap 7, afbeelding 1 van 1
    • Close the cartridge compartment cover.
    • The printer should make a sound from the cartridges going back to their resting position.
Conclusie
Allow for the cartridge holder to reposition and you are ready to print!
5 andere personen hebben deze handleiding voltooid.
2 opmerkingen
Hi if I replace the ink cartridge with a refill the printer has an error message E16 which I know means cartridge is out of ink. How do I override this message to keep printing. I have a Canon TS3360. Jenny.
Jenny - Antwoord
My Pixma TS3300 printer is giving an error message E14 since I replaced the empty cartridges with new 245XL and 246XL cartridges. These should be compatible but aren't working. Please help!
Susan Gardner - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 15
Afgelopen 7 dagen: 55
Afgelopen 30 dagen: 306
Altijd: 16,981
