Ga door naar hoofdinhoud
Canon ImageCLASS MF4350d Scanner Disassembly
Wat je nodig hebt
  1. Canon ImageCLASS MF4350d Scanner Disassembly, Scanner Disassembly: stap 1, afbeelding 1 van 1
    • If at any point you see glass that seems cracked or broken, handle with care. Broken glass is sharp and can cause serious damage.
    • Lift up the lid. Then be sure to examine the glass. If there are any cracks or broken fragments handle with extreme care.
  2. Canon ImageCLASS MF4350d Scanner Disassembly: stap 2, afbeelding 1 van 3 Canon ImageCLASS MF4350d Scanner Disassembly: stap 2, afbeelding 2 van 3 Canon ImageCLASS MF4350d Scanner Disassembly: stap 2, afbeelding 3 van 3
    • Locate the black and white hinges.
    • Gently lift out the black and white hinges.
  3. Canon ImageCLASS MF4350d Scanner Disassembly: stap 3, afbeelding 1 van 3 Canon ImageCLASS MF4350d Scanner Disassembly: stap 3, afbeelding 2 van 3 Canon ImageCLASS MF4350d Scanner Disassembly: stap 3, afbeelding 3 van 3
    • Next, locate and remove the four 10mm screws.
  4. Canon ImageCLASS MF4350d Scanner Disassembly: stap 4, afbeelding 1 van 1
    • Gently, pry off the top plate, starting from the back of the printer.
  5. Canon ImageCLASS MF4350d Scanner Disassembly: stap 5, afbeelding 1 van 2 Canon ImageCLASS MF4350d Scanner Disassembly: stap 5, afbeelding 2 van 2
    • After you have taken off the plate, check to make sure that there is no broken glass. If there is broken glass handle it with gloves. Broken glass, if handled improperly, can cause physical injury.
Conclusie
5 andere personen hebben deze handleiding voltooid.
Tanner Papenfuss
560 Reputatie
4 handleidingen geschreven
Cal Poly, Team 13-1, Forte Fall 2013 Lid van Cal Poly, Team 13-1, Forte Fall 2013
CPSU-FORTE-F13S13G1
5 Leden
16 handleidingen geschreven
Één opmerking
The paper tore and is now not visible. How do I remove the printer's components to access the paper deep in the machine? Is there a method to factory reset the machine? Can I somehow make the rollers rotate to attempt to pushing the paper out?
Kyle - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 26
Altijd: 4,968
