Ga door naar hoofdinhoud
Deze demontage is geen reparatiehandleiding. Om je Canon GP-E2 te repareren, gebruik onze reparatiehandleidingen.
  1. Canon GP-E2 GPS Receiver Hot Shoe Teardown, Canon GP-E2 GPS Receiver Hot Shoe Teardown: stap 1, afbeelding 1 van 1
    • Open the battery cover and remove the AA battery.
  2. Canon GP-E2 GPS Receiver Hot Shoe Teardown: stap 2, afbeelding 1 van 2 Canon GP-E2 GPS Receiver Hot Shoe Teardown: stap 2, afbeelding 2 van 2
    • Remove the three long screws from the top-left, top-right, and bottom-right corners.
    • Remove the short screw from the bottom-left corner.
  3. Canon GP-E2 GPS Receiver Hot Shoe Teardown: stap 3, afbeelding 1 van 2 Canon GP-E2 GPS Receiver Hot Shoe Teardown: stap 3, afbeelding 2 van 2
    • Pull the two halves of the device apart, but don't try to separate them entirely yet. Cables connect the two pieces.
    • Remove the battery cover from its hole.
    • Disconnect the sliding connector.
    • Remove four screws.
    • Desolder the ground pin. The hot shoe can now be removed.
  4. Canon GP-E2 GPS Receiver Hot Shoe Teardown: stap 4, afbeelding 1 van 3 Canon GP-E2 GPS Receiver Hot Shoe Teardown: stap 4, afbeelding 2 van 3 Canon GP-E2 GPS Receiver Hot Shoe Teardown: stap 4, afbeelding 3 van 3
    • Remove the lock pin with the spring by unscrewing the screw.
    • Remove the four screws with smaller heads from the bottom, then remove the hot shoe and the metal shield.
    • Remove the screws with bigger heads that have springs attached.
    • Be gentle when you take out the screws. Do not strip the screws.
  5. Canon GP-E2 GPS Receiver Hot Shoe Teardown: stap 5, afbeelding 1 van 2 Canon GP-E2 GPS Receiver Hot Shoe Teardown: stap 5, afbeelding 2 van 2
    • Next remove pins.
    • Desolid four pins
    • Remove PCB.
  6. Canon GP-E2 GPS Receiver Hot Shoe Teardown: stap 6, afbeelding 1 van 3 Canon GP-E2 GPS Receiver Hot Shoe Teardown: stap 6, afbeelding 2 van 3 Canon GP-E2 GPS Receiver Hot Shoe Teardown: stap 6, afbeelding 3 van 3
    • Remove PCB
    • Remove pins from case
Arsen
145 Reputatie
1 Handleiding geschreven
2Gids Commentaar
Volgens mij is stap 5 te vroeg afgebeeld. Ik moet de schroefjes van de metalen voet aandraaien, maar kan dat als alleen de rode groundpin is losgesoldeerd?
Louis Dederen - Antwoord Deel
Hi mate @louisdederen
For removing hot shoe part you should desolder gnd pin and unscrew 4 screws over PCB, pins you may to remove in case if you want to remove PCB from housing
Arsen - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 40
Altijd: 809
