Inleiding
Prerequisite Only
Removing the top casing from the camera is necessary to perform maintenance or replace components such as the flash module, or any buttons located on the top of the camera. In order to remove the top casing, the back and front casings must both be removed.
Wat je nodig hebt
Place the camera upside down, and position it to where the back of the camera is visible.
Place the camera on its side with the soft touch grip facing up and the top of the camera facing right.
Remove the single 10 mm JIS #00 shoulder screw.
Remove the two 6 mm JIS #00 screws.
Één andere persoon heeft deze handleiding voltooid.
