Ga door naar hoofdinhoud
Canon EOS Rebel XS LCD Replacement
Wat je nodig hebt
  1. Canon EOS Rebel XS LCD Replacement, Latch Side Cover: stap 1, afbeelding 1 van 1
    • Remove the two 3mm (1/8") black screws from the side cover using a #00 Phillips screwdriver.
  2. Canon EOS Rebel XS LCD Replacement: stap 2, afbeelding 1 van 1
    • On the bottom, remove the 6mm (13/64") screw with the #00 Phillips Screwdriver.
    • Pry up the panel; starting from the front/bottom corner, as indicated.
    • There's a concealed lip, under the opposite edge.
  3. Canon EOS Rebel XS LCD Replacement, Back Cover: stap 3, afbeelding 1 van 1
    Gereedschap gebruikt in deze stap:
    • Remove the three long black screws from the bottom using a #00 Phillips screwdriver.
    • Use tweezers to lift the panel.
  4. Canon EOS Rebel XS LCD Replacement: stap 4, afbeelding 1 van 1
    • Once you have detached the back cover, use a pair of tweezers to lightly pull on strap found connecting the back cover to the camera.
  5. Canon EOS Rebel XS LCD Replacement, LCD: stap 5, afbeelding 1 van 1
    • Use the tweezers to gently remove the straps (in the teal box).
    • Use the Phillips Screwdriver to remove the four screws (in the red dots).
    • Use your fingers to remove the silver plate.
  6. Canon EOS Rebel XS LCD Replacement: stap 6, afbeelding 1 van 1
    • Use the Spudger on the edges of the screen.
    • Once one end is lose, use the tweezers to lift the screen.
Conclusie
3 andere personen hebben deze handleiding voltooid.
Daniel Bussone
1.260 Reputatie
11 handleidingen geschreven
Cal Poly, Team 3-41, Regan Winter 2011 Lid van Cal Poly, Team 3-41, Regan Winter 2011
CPSU-REGAN-W11S3G41
2 Leden
21 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 7
Altijd: 7,371
