Inleiding
Use this guide to replace the LCD. The LCD tends to fade after about five years.
Onderdelen
Geen onderdelen opgegeven.
Remove the two 3mm (1/8") black screws from the side cover using a #00 Phillips screwdriver.
Remove the three long black screws from the bottom using a #00 Phillips screwdriver.
Use tweezers to lift the panel.
Use the tweezers to gently remove the straps (in the teal box).
Use the Phillips Screwdriver to remove the four screws (in the red dots).
Use your fingers to remove the silver plate.
3 andere personen hebben deze handleiding voltooid.
