Deze versie kan foutieve bewerkingen bevatten. Schakel over naar de recentste gecontroleerde momentopname.
Wat je nodig hebt
Deze stap is niet vertaald. Help het te vertalen
Remove the two 3mm (1/8") black screws from the side cover using a #00 Phillips screwdriver.
On the bottom, remove the 6mm (13/64") screw with the #00 Phillips Screwdriver.
Pry up the panel; starting from the front/bottom corner, as indicated.
There's a concealed lip, under the opposite edge.
Remove three medium length screws from the bottom of the camera
Remove the two medium length screws on the front panel of the camera above the lens mount.
Once you done, you may use the Spudger to panel from non-grip side.
Remove the three long black screws from the bottom using a #00 Phillips screwdriver.
Use tweezers to lift the panel.
Once you have detached the back cover, use a pair of tweezers to lightly pull on strap found connecting the back cover to the camera.
Remove the following ribbons with the tweezers by gently pulling on them.
Remove the three black screws, near the eye piece, using the Phillips Screwdriver.
Remove the cable heads attached on the front side of the camera next to the lens mount.
You can use your fingers to pull the top panel of the camera.
After removing the top panel, you can use your fingers to remove the eye piece from the camera.
Één andere persoon heeft deze handleiding voltooid.
2 opmerkingen
How do you replace the internal battery?
