Deze versie kan foutieve bewerkingen bevatten. Schakel over naar de recentste gecontroleerde momentopname.
Wat je nodig hebt
Deze stap is niet vertaald. Help het te vertalen
Remove the two 3mm (1/8") black screws from the side cover using a #00 Phillips screwdriver.
On the bottom, remove the 6mm (13/64") screw with the #00 Phillips Screwdriver.
Pry up the panel; starting from the front/bottom corner, as indicated.
There's a concealed lip, under the opposite edge.
Remove three medium length screws from the bottom of the camera
Remove the two medium length screws on the front panel of the camera above the lens mount.
Once you done, you may use the Spudger to panel from non-grip side.
Remove the two 4.5mm (.18in) long black screws from the camera grip using a #00 Phillips screwdriver.
Use your fingertip to pry off the external shutter port cover.
Remove the two 5mm (.20in) long silver screws securing the grip to the camera using a #00 Phillips screwdriver.
Use the spudger tool to carefully pry the grip from the rest of the camera.
Once the grip is loose, use your fingers to remove it from the camera.
Één andere persoon heeft deze handleiding voltooid.
Één opmerking
Little confused. Some pics are from a analog Canon, other from a digital Canon...
