Ga door naar hoofdinhoud
Canon EOS Rebel XS Grip Replacement
Wat je nodig hebt
  1. Canon EOS Rebel XS Grip Replacement, Latch Side Cover: stap 1, afbeelding 1 van 1
    • Remove the two 3mm (1/8") black screws from the side cover using a #00 Phillips screwdriver.
  2. Canon EOS Rebel XS Grip Replacement: stap 2, afbeelding 1 van 1
    • On the bottom, remove the 6mm (13/64") screw with the #00 Phillips Screwdriver.
    • Pry up the panel; starting from the front/bottom corner, as indicated.
    • There's a concealed lip, under the opposite edge.
  3. Canon EOS Rebel XS Grip Replacement, Disassembling Canon EOS Rebel XS Front Cover: stap 3, afbeelding 1 van 1
    • Remove three medium length screws from the bottom of the camera
  4. Canon EOS Rebel XS Grip Replacement: stap 4, afbeelding 1 van 1
    • Remove the two medium length screws on the front panel of the camera above the lens mount.
    • Once you done, you may use the Spudger to panel from non-grip side.
    • If you start on the grip side, it will be more challenging to loosen the panel.
  5. Canon EOS Rebel XS Grip Replacement, Grip: stap 5, afbeelding 1 van 1
    • Remove the two 4.5mm (.18in) long black screws from the camera grip using a #00 Phillips screwdriver.
  6. Canon EOS Rebel XS Grip Replacement: stap 6, afbeelding 1 van 1
    • Use your fingertip to pry off the external shutter port cover.
  7. Canon EOS Rebel XS Grip Replacement: stap 7, afbeelding 1 van 1
    • Remove the two 5mm (.20in) long silver screws securing the grip to the camera using a #00 Phillips screwdriver.
  8. Canon EOS Rebel XS Grip Replacement: stap 8, afbeelding 1 van 3 Canon EOS Rebel XS Grip Replacement: stap 8, afbeelding 2 van 3 Canon EOS Rebel XS Grip Replacement: stap 8, afbeelding 3 van 3
    • Use the spudger tool to carefully pry the grip from the rest of the camera.
  9. Canon EOS Rebel XS Grip Replacement: stap 9, afbeelding 1 van 1
    • Once the grip is loose, use your fingers to remove it from the camera.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Daniel Bussone
1.260 Reputatie
11 handleidingen geschreven
Cal Poly, Team 3-41, Regan Winter 2011 Lid van Cal Poly, Team 3-41, Regan Winter 2011
CPSU-REGAN-W11S3G41
2 Leden
21 handleidingen geschreven
1Gids Commentaar
Little confused. Some pics are from a analog Canon, other from a digital Canon...
Gustavo Aguiar - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 10
Altijd: 3,661
