Ga door naar hoofdinhoud
Canon EOS Rebel T6i Flash Assembly Replacement
Wat je nodig hebt
  1. Canon EOS Rebel T6i Flash Assembly Replacement, Flash Assembly: stap 1, afbeelding 1 van 3 Canon EOS Rebel T6i Flash Assembly Replacement, Flash Assembly: stap 1, afbeelding 2 van 3 Canon EOS Rebel T6i Flash Assembly Replacement, Flash Assembly: stap 1, afbeelding 3 van 3
    • Remove two 6.8 mm JIS #000 screws on the right side.
    • Remove six 5.3 mm JIS #000 screws on the bottom.
    • Remove two 5.3 mm JIS #000 screws on either side of the viewfinder.
  2. Canon EOS Rebel T6i Flash Assembly Replacement: stap 2, afbeelding 1 van 2 Canon EOS Rebel T6i Flash Assembly Replacement: stap 2, afbeelding 2 van 2
    • Remove one 5.9 mm JIS #000 screw on the top right.
    • Remove one 3.4 mm JIS #000 screw on the top left.
  3. Canon EOS Rebel T6i Flash Assembly Replacement: stap 3, afbeelding 1 van 3 Canon EOS Rebel T6i Flash Assembly Replacement: stap 3, afbeelding 2 van 3 Canon EOS Rebel T6i Flash Assembly Replacement: stap 3, afbeelding 3 van 3
    • Using a metal spudger, pry the rubber grip off of the casing on the left side of the camera.
    • Potential for device damage: Be careful not to rip the rubber with the metal spudger.
    • Remove five silver 5.8 mm JIS #000 screws from underneath the grip.
  4. Canon EOS Rebel T6i Flash Assembly Replacement: stap 4, afbeelding 1 van 2 Canon EOS Rebel T6i Flash Assembly Replacement: stap 4, afbeelding 2 van 2
    • Using the metal spudger, pry the rubber grip located just below the turndial.
    • Potential for device damage: Be careful not to rip the rubber.
  5. Canon EOS Rebel T6i Flash Assembly Replacement: stap 5, afbeelding 1 van 2 Canon EOS Rebel T6i Flash Assembly Replacement: stap 5, afbeelding 2 van 2
    • Carefully use the plastic opening tool to pry the casing apart along the seam.
    • Follow the seam with the plastic tool until the back is ready to remove.
    • Potential for device damage: Make sure you use the grounding strip to remove the chance of discharging static electricity into the internal components.
  6. Canon EOS Rebel T6i Flash Assembly Replacement: stap 6, afbeelding 1 van 3 Canon EOS Rebel T6i Flash Assembly Replacement: stap 6, afbeelding 2 van 3 Canon EOS Rebel T6i Flash Assembly Replacement: stap 6, afbeelding 3 van 3
    • Notice the two connections attaching the back of the camera to the motherboard.
    • To disconnect the white wire, pinch the wire casing and pull it directly out from the camera.
    • This may take a very small amount of strength; however, do not force or pry it.
    • To disconnect the ribbon connector, softly pull the back away from the motherboard. It should come undone with little force.
    • Once removed, set the back in a safe place.
  7. Canon EOS Rebel T6i Flash Assembly Replacement: stap 7, afbeelding 1 van 2 Canon EOS Rebel T6i Flash Assembly Replacement: stap 7, afbeelding 2 van 2
    Gereedschap gebruikt in deze stap:
    • Remove the five ribbon connectors along the bottom of the assembly using either needle nose tweezers or a plastic opening tool to flip the small flaps to the "up" position.
    • Use a nylon spudger to pull each ribbon connector out of its connection using the hole in the center of the ribbon.
  8. Canon EOS Rebel T6i Flash Assembly Replacement: stap 8, afbeelding 1 van 1
    • Remove the button cell battery from the motherboard using a pair of tweezers.
  9. Canon EOS Rebel T6i Flash Assembly Replacement: stap 9, afbeelding 1 van 2 Canon EOS Rebel T6i Flash Assembly Replacement: stap 9, afbeelding 2 van 2
    • Disconnect the small plastic connectors on the top left corner of the motherboard by gripping the small plastic portion of the wire and gently pulling out of the connector.
    • Disconnect the three ribbon connectors along the top.
    • Don't detach the connectors underneath or the ribbon connectors with the foam block, as these will be removed later.
  10. Canon EOS Rebel T6i Flash Assembly Replacement: stap 10, afbeelding 1 van 2 Canon EOS Rebel T6i Flash Assembly Replacement: stap 10, afbeelding 2 van 2
    • Remove the four screws from the front of the camera. There are two screws above the lens mount and two screws inside the lens mount.
    • Remove the four screws from the bottom of the camera.
  11. Canon EOS Rebel T6i Flash Assembly Replacement: stap 11, afbeelding 1 van 3 Canon EOS Rebel T6i Flash Assembly Replacement: stap 11, afbeelding 2 van 3 Canon EOS Rebel T6i Flash Assembly Replacement: stap 11, afbeelding 3 van 3
    • Using the plastic opening tool, pry the front of the casing off of the camera.
    • Warning: Electric Shock! Be careful not to touch the terminals of the capacitor (black cylinder). This can cause the capacitor to discharge.
  12. Canon EOS Rebel T6i Flash Assembly Replacement: stap 12, afbeelding 1 van 2 Canon EOS Rebel T6i Flash Assembly Replacement: stap 12, afbeelding 2 van 2
    • Remove the yellow and red connections on the front near the black cylinder (capacitor).
    • The yellow connector will just pop out if pried from the bottom using a plastic opening tool.
    • The red connector will pull out of the casing with either a plastic opening tool or a thin set of tweezers.
  13. Canon EOS Rebel T6i Flash Assembly Replacement: stap 13, afbeelding 1 van 1
    • Remove the diopter adjustment knob next to the viewfinder using a JIS #000 screwdriver.
  14. Canon EOS Rebel T6i Flash Assembly Replacement: stap 14, afbeelding 1 van 2 Canon EOS Rebel T6i Flash Assembly Replacement: stap 14, afbeelding 2 van 2
    • Remove the entire upper flash assembly by gently pulling it up and off the camera.
    • The flash assembly is sold as a single piece.
Conclusie
3 andere personen hebben deze handleiding voltooid.
Shane Riding
861 Reputatie
4 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 14
Afgelopen 30 dagen: 58
Altijd: 3,739
